2008 taurus suspension problems - Taurus Car Club of America : Ford Taurus Forum
post #1 of 13 (permalink) Old 02-28-2017, 03:28 PM Thread Starter
Year: 2008
Engine: 3.5L Ti-VCT V6
I recently bought a 2008 ford taurus sel awd. I can't get a four wheel alignment because the shop says it needs rear ball joints. I cannot find any at any of my parts houses. Does the 2008 taurus awd have rear ball joints. Also I cannot find any sway bar bushings, that mount to the body anywhere. What is up with these problems?
ronoharold is offline
post #2 of 13 (permalink) Old 02-28-2017, 03:45 PM
breeves002
Sam's Avatar
Year: 2008
Trader Score: 8 reviews
Odd. Yeah I don't think there is a ball joint on the rear. Just some rubber bushings. There are two lateral arms and a trailing arm. Theres an upper control arm too but I don't think it has a ball joint, just a rubber bushing. Take a look. Someone correct me if I'm wrong. I'm honestly not sure how much alignment can actually be done on the rear.
2017 Fusion Energi Platinum
2016 Ford Mustang GT Premium PP Whipple Stage 2
Moved On:
2014 Focus Electric
2008 Mercury Sable Premier
2000 Sable LS Premium Duratec
1997 Mercury Grand Marquis GS
Sam is offline
post #3 of 13 (permalink) Old 02-28-2017, 07:47 PM Thread Starter
Year: 2008
I was wondering if this guy at the alignment shop knew what he was talking about.
post #4 of 13 (permalink) Old 03-01-2017, 08:57 AM
andrewcu's Avatar
Year: 2010
Engine: 3.5L Cyclone V6
go get a second opinion. Never hurts
Current Projects:
"Fool me once shame on you, fool me twice can't get fooled again"
All green everything!
andrewcu is offline
post #5 of 13 (permalink) Old 03-06-2017, 01:29 PM Thread Starter
Year: 2008
Another problem I found with this 2008 ford taurus is I can't find sway bar bushings, which attach to the body. Not the links. Ford told me I would have to buy each sway bar to get the bushings. That is not a good way to do business. Does anyone know where I can find bushings for this ford? I know the front sway bar is 26mm width and the rear is 14mm.
post #6 of 13 (permalink) Old 03-06-2017, 02:26 PM
breeves002
Sam's Avatar
Year: 2008
Why do you need the bushings? Thats a really odd thing to fail for a car from 2008. If you follow the sway bar the bushings are where the sway bar attaches to the body.
Moved On:
2014 Focus Electric
Sam is offline
post #7 of 13 (permalink) Old 03-06-2017, 02:54 PM Thread Starter
Year: 2008
And that is the bushings I'm wanting to replace. They make a clunking sound when I hit bumps and holes in the road.
post #8 of 13 (permalink) Old 03-07-2017, 09:40 AM
breeves002
Sam's Avatar
Year: 2008
You're sure its the bushings? I'm really doubting its the bushings on the sway bar.
Thats such an unlikely failure.
First check
-Control arms
-Strut mounts/struts
-Sway bar end links
MUCH more common to go bad.
Moved On:
2014 Focus Electric
Sam is offline
post #9 of 13 (permalink) Old 03-07-2017, 08:28 PM Thread Starter
Year: 2008
Actually I just had the whole front end redone. Including struts, sway bar links, and control arms. The bushings are cracked and swelling outside the brackets.
post #10 of 13 (permalink) Old 03-08-2017, 11:28 AM
breeves002
Sam's Avatar
Year: 2008
Just an odd failure. Usually even when they get old and cracked they don't make noise unless they are completely gone. Are you sure they replaced the strut mounts when they did the front? The rear strut mounts are so hard to replace so those likely aren't replaced if those struts were replaced. The rear struts fail especially fast on this car too. I doubt it is rear strut mounts but the struts themselves can make noise.
I take it you found the bushings though? Replace and let me know if it fixes the problem.
Moved On:
2014 Focus Electric
Sam is offline
1999 Taurus SE ABS and circuit problems got89 Maintenance and Repair 14 07-26-2015 06:11 PM
Several issues with 2008 Taurus HVAC bitshift32 5th and 6th Gen Maintenance and Repair 6 07-15-2015 04:32 PM
2008 Taurus blower motor only working on high mrthinkshesfunny 5th and 6th Gen Maintenance and Repair 2 06-29-2015 07:22 PM
Nate's 2008 Taurus SEL NHarris Taurus and Sable Project Log 76 08-11-2014 11:08 PM
2008 Mustang Wheel on a 2008 Taurus hamsalad2 5th and 6th Gen Aesthetics, Interior, Wheels and Tires 3 12-12-2013 01:44 AM
