Hyper Flash Problem - Taurus Car Club of America : Ford Taurus Forum
 1Likes
  • 1 Post By jaedenhudson14
post #1 of 4 (permalink) Old 03-10-2019, 04:45 PM Thread Starter
jaedenhudson14's Avatar
Chapter: Northern
Year: 2013
Engine: 3.5L EcoBoost V6
Hyper Flash Problem
08 Taurus. For whatever reason out of no where the car has decided to hyper flash on both sides with the turn signals. All bulbs are good. None of them are LED. Forscan is pulling code B2A2B - Left Corner Lamp Output Circuit Short to Ground and B2A2C - Right Corner Lamp Output Circuit Short to Ground. I have checked all wires. None are having issues. I tried doing a SJB reset in forscan and it tells me that feature is not supported by that module. As built has not been messed with. Any ideas? I am starting to guess an issue with the SJB itself
jaedenhudson14 is offline
post #2 of 4 (permalink) Old 03-10-2019, 06:15 PM Thread Starter
Chapter: Northern
Year: 2013
After a crap ton of googling I found the issue. I had to go to a Lincoln navigator page but I figured out that a blown fog light fuse will cause this. So for anyone else with this issue, check the fog light fuse. Would have never guessed that would have been the cause.
brn likes this.
post #3 of 4 (permalink) Old 03-10-2019, 07:58 PM
AdmiralSparklez's Avatar
Year: 2013
Engine: 3.5L Cyclone V6
Was actually just about to suggest the battery being a possible culprit.
AdmiralSparklez is offline
post #4 of 4 (permalink) Old 03-10-2019, 08:38 PM Thread Starter
Chapter: Northern
Year: 2013
I originally thought that too but then I found out that fuse was the issue. I am going to guess that is the cars way of telling you the fog lights don't work? Weird either way.
Hyper Flash Fix for LED Bulbs - SJB Reconfiguration jamesu 5th and 6th Gen Electronics, Security, Audio and Visual 1 09-23-2017 06:50 AM
Acceleration Problem After Downshift - Must Stop Throwing Parts At Problem Celtic Maintenance and Repair 9 03-13-2015 01:12 PM
Electrical Ignition Problem - Actuator Rod Not Engaging northtexas55693 Maintenance and Repair 2 06-04-2014 10:03 PM
99 Duratec elusive shift problem in O/D only dskl Maintenance and Repair 7 01-27-2014 09:00 PM
You may post new threads
You may post replies
