10 Taurus Halogen Projector Issues - Taurus Car Club of America : Ford Taurus Forum
post #1 of 4 (permalink) Old 10-10-2018, 11:03 PM Thread Starter
Pratik Huddar's Avatar
Year: 2010
Engine: 3.5L Cyclone V6
Hey folks, my 2010 Taurus headlamps are acting up more than often.
LH Headlamp: There's not much difference between the high beam and the low beam light thrown out (low beams seem way too bright). Also, the cutoff is very bad, oblique on the left and there is a huge dark spot in the center of the lamp. Anyone tried opening up a headlamp to change the condenser lens or solenoid activated shutter on these?
RH Headlamp: Light seems way too low, but the cutoff is decent. Any recommended super-bright bulbs other than stock halogens?
Also, any suggestions on where I can find a used set of headlamps?
Looking forward to suggestions!
Thanks!
If you don't look back at your car after locking it in the parking lot, you don't own that car!
Pratik Huddar is offline
post #2 of 4 (permalink) Old 02-27-2019, 06:01 AM
Year: 2015
Engine: 3.5L EcoBoost V6
My stock halogen lights were absolutely garbage, it almost was as if I were driving with no lights on. I purchased the Lasfit LED s and they are amazing! Just as good as my oem HIDs in my Honda Odyssey! I highly recommend, however when I first installed them they looked horrible. I had to orient the LED chips so that they were in a 3 to 9 O'Clock position within my headlights.
TheRealist is offline
post #3 of 4 (permalink) Old 03-08-2019, 10:47 PM
AdmiralSparklez's Avatar
Year: 2013
The projector shouldn't ever be an issue unless the headlamp assembly sat with the bulb removed leaving an entry point for the elements to enter into the projector housing.
I've done quite a lot to my headlights, including the projectors. I'd first try new bulbs if I was in your situation. They make LED and HID bulbs that are designed to be put in the stock halogen housing as they match the beam pattern of the halogen bulbs. Do not put full on LEDs or HIDs in the housing. The cutoff is nowhere near where it needs to be for those and you WILL get pulled over.
If it does come down to the headlamps themselves, you can try upgrading the projectors or snag a set of used lamps that could be in better shape. Try car-part.com for finding used parts. Saved me unbelievable amounts of money.
AdmiralSparklez is online now
post #4 of 4 (permalink) Old 03-27-2019, 10:06 PM
hey therealist - lasfit has several different series of led headlights - which series did you get and did you have to use the decoder for any dash light issues .... thanks
johnman58j is offline
Spark Plugs unit731 Engine and Drivetrain 19 06-18-2018 01:30 PM
Ford Taurus Fog Light LEDs! Plug & Play Install! Same-day Shipping! USA Made SLF! Diode Dynamics Diode Dynamics 10 04-30-2018 05:50 PM
The Tamaro or I call her Sinnamon: A True Transformation!!! Tamaro Taurus and Sable Project Log 41 04-24-2018 04:11 PM
Ford Taurus Reliability - Better Info mkaresh Taurus and Sable General Discussion 73 11-21-2016 01:46 PM
New member, 2nd Taurus, 4th Ford, former GM'er Rob Lee Introduction Forum 11 06-06-2014 09:57 AM
