2010 SHO HID bulb replacement? - Taurus Car Club of America : Ford Taurus Forum
 1Likes
  • 1 Post By AdmiralSparklez
post #1 of 6 (permalink) Old 05-06-2018, 06:30 PM Thread Starter
Year: 2010
Engine: 3.5L EcoBoost V6
I did a search on HID bulbs if this has been covered someone please provide the link. Thank you.
I wanted to change the temp of my HIDs to a whiter color. I changed my passenger side no problem. My driver side though looks nothing like my passenger side. The bulbs are the same but that's it. I cannot get my driver side bulb out. I have taken the headlights completely out. I even opened the bottom up to get a better view of the bulb. I have tried pliers, turned counter clock wise, and still nothing. I didn't want to break the bulb so I quit and put the headlight back on.
So how do I get the driver side headlight bulb out?
Code AiR is offline
post #2 of 6 (permalink) Old 02-24-2019, 05:04 PM
JRV1631's Avatar
Year: 2016
I know this is an old thread but, Iím having some of the same issues. My previous manufacturer was very simple. Pull up two rods, unplug the wires and the whole assembly came out in your lap. Iíve been able to remove the cover and zip tie on the passenger side. But I canít get my meat hooks in there to twist the bulb. I can see the bulb, just canít get in there enough to turn it. Any suggestions? Can you remove the whole assembly? The drivers side should probably be easier. Just take out the CAI. But I want to be sure I have the hard side done first.
Any input would be greatly appreciated!
2016 SHO, K&N CAI, H&R Sport Springs, Diablo Sport 93 Oct. Tune, DriveBright.com Switchback DRLís, Lamin-X Headlight Tint, Roof Spoiler, JLT Oil Catch Can.
JRV1631 is offline
post #3 of 6 (permalink) Old 02-24-2019, 07:02 PM
AdmiralSparklez's Avatar
Year: 2013
Engine: 3.5L Cyclone V6
I don't remember mine being difficult at all when I rebuilt my headlights for HIDs. My service manual calls for turning the headlight bulb one-eighth counterclockwise and removing the bulb.
JRV1631 likes this.
AdmiralSparklez is offline
post #4 of 6 (permalink) Old 02-26-2019, 08:19 AM
JRV1631's Avatar
Year: 2016
Thanks Admiral. At least that confirms it work as standard bulb removal. Maybe the wifeís smaller hands are needed. She helped me hook up the trigger wire for the drive right.com drlís/turn indicators.
JRV1631 is offline
post #5 of 6 (permalink) Old 02-26-2019, 10:51 AM
Year: 2013
Benefits of being a 130lb 22 year old, I can fit my hands and arms in those little areas haha. I don't believe there are clips on the sides of the bulbs from what I remember. My Mustang has to clips to push on both sides and then you pull the headlight bulb out. My service manual never said anything about that but try your best to take as close of a look as possible because manufacturers tend to change little things here and there between trims and years.
post #6 of 6 (permalink) Old 02-27-2019, 08:15 PM
JRV1631's Avatar
Year: 2016
.....I don't believe there are clips on the sides of the bulbs from what I remember. My Mustang has to clips to push on both sides and then you pull the headlight bulb out. My service manual never said anything about that but try your best to take as close of a look as possible because manufacturers tend to change little things here and there between trims and years.
Thanks again. Iíll keep an eye out for that.
JRV1631 is offline
Front turn signal bulb replacement on 95 kioolt Maintenance and Repair 3 07-29-2018 05:25 PM
Ford Taurus OEM HID Replacement Bulbs! Direct Replacement! Same-Day Shipping! Diode Dynamics Diode Dynamics 9 04-30-2018 02:31 PM
Dome light bulb replacement 94SableGuy Maintenance and Repair 0 01-23-2018 11:23 PM
2010 reverse light bulb size andrewcu 5th and 6th Gen Electronics, Security, Audio and Visual 5 03-31-2016 01:28 PM
Gen 4 Interior Light Bulb Replacement Shopping Lint (type and quantity) 2k3SEL Electronics, Security, Audio and Visual 11 10-06-2015 09:51 PM
