Beginning on my audio build - Taurus Car Club of America : Ford Taurus Forum
 10Likes
post #1 of 158 (permalink) Old 03-03-2015, 04:42 AM Thread Starter
tgrfly4's Avatar
Financial Mistake--'10 Taurus Trunk Wall
So I am currently working on an audio build in my Bull. Weather is kinda working against me so I am trying to knock out some of the little things that I can do inside.
Build consists of:
Sub Stage
2 D.7 ohm 12" DC Audio Lvl4s ( Fully Built)
Amp: AudioQue 1200D
Mids
Front Doors: 6.5" PRV Neos
Rear Doors: 6.5" Crescendo Audio PWX6s
Amp: Crescendo Audio 550.2
Highs
Tweeters: Crescendo Audio RTS1
Amp: Rockford Fosgate PBR300.4
Battery
XS Power D6500
Wire
All Sky High wire
0 awg Power from battery back
0 awg Big 3
Sky High RCAs
Factory Integration
JL CleanSweep
tgrfly4 is offline
post #2 of 158 (permalink) Old 03-03-2015, 05:09 AM Thread Starter
tgrfly4's Avatar
Fiberglass Tweeter Mounts
My Bull currently has the full 12 speaker Sony sound system, but with this build I will not be using any of it. With having the tweeters already mounted into the A pillar and having a cover over them I have decided to make a pod that replaces the cover and will allow me to convert it back to stock if/when I decide to sell the car.
At the beginning of this project I started out one way and then getting further into it realized that my idea was not going to work like I had wanted it to so I had to completely start over from scratch. After talking with a buddy of mine who has helped me on all my audio builds he helped me figure out how to attack this project.
So here is where I started...
So I took the cover off and taped off my pillar and took some fleece and made a fiberglass mold of the recess where the cover sits. From there I had to make my own speaker rings out of fiberglass to mount the tweeters in. From here it got tricky. I took dow rod and mounted my speaker ring to them and them mounted them to my template.
Speaker Ring
Pod Skeletons
Roughly
After I got everything where I needed it I made another FG ring that was a bit wider than the tweeter itself and mounted it on top of the original to give the pod a little more height and give it a little more surface area around the edge of the tweeter. I then used super glue and started wrapping the skeleton of the pod.
Wrapped and resined
Currently only have the driver's side pod wrapped. Going to try and get the passenger side wrapped and resined today. This will give me some time to start smoothing out the drivers side pod while the passenger side is curing.
After all is said and done I'm going to wrap the pillars and the pods in black suede to accent the already all black interior.
I will update this post as I make more progress.
tgrfly4 is offline
post #3 of 158 (permalink) Old 03-03-2015, 08:02 AM
jrdnhsnbrg's Avatar
Year: 2013
Engine: 3.5L Ti-VCT V6
Great choice on, well, everything! From the speakers to the subs, amps, batteries, and wiring, it looks like you've done your research. I'm a bit of a car audio nut myself, and as soon as I have my car paid off I'll be building a SQ-oriented system myself. I can't wait to watch this come together! You have any plans to upgrade your sub amp? Those DCs can handle more than that AQ 1200.
jrdnhsnbrg is offline
post #4 of 158 (permalink) Old 03-03-2015, 08:51 AM Thread Starter
tgrfly4's Avatar
Unfortunately as of right now, no. I know those Lvl4s are laughing at the 1200 but I can't complain when they did a 143.5 in my Explorer I had before.
tgrfly4 is offline
post #5 of 158 (permalink) Old 03-03-2015, 09:04 AM
jrdnhsnbrg's Avatar
Year: 2013
Explorers (exploders) are stupid easy to get loud, a trunk car is a whole different ballgame. I had a pair of 12s on 4k in my old car, trunk wall, was right around a 145. Same cone area, over triple the power, only 1db louder.
post #6 of 158 (permalink) Old 03-03-2015, 01:14 PM
Nice to see there are some people who know what they're doing.
SilverPellet is offline
post #7 of 158 (permalink) Old 03-03-2015, 06:08 PM
SantaClawZ's Avatar
Looks good so far. Are you planning on firing the subs forward and sealing off the trunk? That tends to be the loudest setup in most trunk cars when done properly and eliminates trunk rattle.
Owner of SounDrive Owner of Team Audiomatic
04 Tahoe
04 Taurus
SantaClawZ is offline
post #8 of 158 (permalink) Old 03-03-2015, 08:56 PM Thread Starter
tgrfly4's Avatar
Yes sir that is the plan.
tgrfly4 is offline
post #9 of 158 (permalink) Old 03-03-2015, 11:45 PM Thread Starter
tgrfly4's Avatar
Got the driver's side finished up and pretty much ready to wrap...
tgrfly4 is offline
post #10 of 158 (permalink) Old 03-08-2015, 12:46 PM Thread Starter
tgrfly4's Avatar
Got both pods finished up. Waiting on my suede to get here which will be Tuesday. They aren't identical, but they are pretty damned close.
tgrfly4 is offline
2004 Taurus SES - Audio Build SantaClawZ Taurus and Sable Project Log 14 10-24-2014 05:19 PM
General Audio questions Dynesteelcoat Electronics, Security, Audio and Visual 14 10-19-2014 07:56 PM
Huge audio build. Major sag in suspension. New member throttle98 Suspension, Handling and Brakes 10 10-16-2013 02:18 AM
Audio Build Component Suggestions antleo Electronics, Security, Audio and Visual 34 08-16-2013 02:21 AM
