LED bulb sizes - Taurus Car Club of America : Ford Taurus Forum
post #1 of 6 (permalink) Old 05-07-2019, 01:47 AM Thread Starter
Year: 2018
Engine: 3.5L Ti-VCT V6
LED bulb sizes
Hey guys new at this and need help with my 2018 Taurus limited. What are the sizes of every bulb on my car interior and exterior. Want to convert it all to LEDs, thanks in advance! Cheers
mathewtassone35 is offline
post #2 of 6 (permalink) Old 05-08-2019, 07:18 PM
jaedenhudson14's Avatar
Chapter: Northern
Year: 2013
Engine: 3.5L EcoBoost V6
I did this myself. Here is what you need.
Front turn signals: 3157.
Headlights: D3S if you have factory HIDs or 9012 if you have factory halogen.
Front sidemarker: 168/194
All interior bulbs: 168/194 - For middle domelight do this:
Reverse lamps: 168/194 or 921.
Rear brake, side marker, and Turn signals are already LED.
Third brake lamp is already LED.
License plate lamps: 36mm Festoon or you can go the led assembly route here https://www.amazon.com/s?k=ford+taur...f=nb_sb_noss_1
Mirror puddle lights are a pain to open up and leak so I recommend these: https://www.amazon.com/s?k=ford+mirr...f=nb_sb_noss_1
The trunk light is a 46mm festoon if I recall.
When changing your front turn signals, I recommend you get forscan and turn bulb outage detection off in the BCM so you do not need load resistors. Here is a tutorial to learn that if you do not know how https://www.taurusclub.com/forum/114...dule-data.html
Lastly, I recommend you get good quality bulbs, or you will be changing them often which negates the purpose of them in the first place. Diode Dynamics, and Morimoto are a couple good brands.
jaedenhudson14 is offline
post #3 of 6 (permalink) Old 05-09-2019, 10:17 PM Thread Starter
Year: 2018
Thanks
post #4 of 6 (permalink) Old 05-09-2019, 10:19 PM Thread Starter
Year: 2018
How are the Sirius led lights off amazon?
post #5 of 6 (permalink) Old 05-09-2019, 10:20 PM Thread Starter
Year: 2018
Was thinking on going hid for the headlights, was told they work better for projectors.
post #6 of 6 (permalink) Old 05-22-2019, 06:15 PM
Chapter: Northern
Year: 2013
I did try HIDs and the output was better, but because these projectors are designed for halogens from the factory, the HIDs still do not work as best as they should. I ended up getting my headlights retrofitted.
Also because the projectors were not designed for HIDs, you risk burning the reflective material in the projector itself.
Bulb Replacement 95TaurusinSK Taurus and Sable General Discussion 2 03-24-2019 11:13 PM
2010 SHO HID bulb replacement? Code AiR 5th and 6th Gen Electronics, Security, Audio and Visual 5 02-27-2019 08:15 PM
2006 Taurus license bulb replacement kalleberg Maintenance and Repair 1 06-22-2018 09:43 PM
Headlight Bulb Choices? Duncan 5th and 6th Gen Maintenance and Repair 6 05-29-2015 07:59 AM
Bulb Upgrade? jmburke 5th and 6th Gen Aesthetics, Interior, Wheels and Tires 12 02-04-2015 03:44 PM
