TPMS not working - Page 2 - Taurus Car Club of America : Ford Taurus Forum
 2Likes
post #11 of 19 (permalink) Old 12-27-2018, 06:12 PM
Gen 5/6 Forum Moderator
Year: 2017
Model: OTHER
Engine: OTHER
Did you edit the IPC's as-built data during the Sync 3 conversion?
I wish I still had the Taurus's service manual to reference--usually the theory and operation will describe the modules that signal the code and then make the request to the IPC.
I also can't remember which modules had sat on multiple data buses, acting as a gateway between HS and MS can, etc. APIM might have been one.
thefranchise713
thefranchise713 is offline
post #12 of 19 (permalink) Old 12-27-2018, 06:14 PM Thread Starter
jaedenhudson14's Avatar
Chapter: Northern
Year: 2013
Engine: 3.5L EcoBoost V6
I did not touch anything in the IPC. I thought about restoring from my stock backup I made to see if that makes a difference.
jaedenhudson14 is offline
post #13 of 19 (permalink) Old 12-27-2018, 06:19 PM
Year: 2017
Model: OTHER
Engine: OTHER
Are there any U codes stored in the modules when you search for DTCs?
thefranchise713
post #14 of 19 (permalink) Old 12-27-2018, 06:21 PM Thread Starter
Chapter: Northern
Year: 2013
Not that I could see. Completely clean in terms of codes
post #15 of 19 (permalink) Old 12-27-2018, 06:25 PM
Year: 2017
Model: OTHER
Engine: OTHER
Hmm... I wonder what would happen if you attempted to re-train the TPMS (MIGHT be something in the Topic Finder on this, but can't remember). If you have a reset tool, I'd have at it and see what happens.
IPC should walk you through the process once the reset routine is triggered.
thefranchise713
post #16 of 19 (permalink) Old 12-27-2018, 06:27 PM Thread Starter
Chapter: Northern
Year: 2013
Yeah I need to get the tool. That is one thing I am definitely going to try to see if maybe something is up. I am going out right now to double check my APIM as built, as well as double checking the IPC as built to see if anything might be causing it to behave this way.
Also, here is my current APIM as built if there is anything you see that might be off.
Name:	Focus-Taurus Sync 3 Modded asbuilt.PNG
post #17 of 19 (permalink) Old 12-28-2018, 07:47 AM
Year: 2014
Engine: 3.5L Ti-VCT V6
What's the bottom limit pressure that signals the light to come on?
1988 Ford Mustang LX 5.0L
Mustang5L5 is offline
post #18 of 19 (permalink) Old 12-28-2018, 05:33 PM Thread Starter
Chapter: Northern
Year: 2013
So I went out to the car and decided to load my as built backup for the IPC. I remembered that I attempted to do a couple mods a long while ago with the cluster that did not change anything. Turns out I ended up breaking the TPMS doing that despite everything else working correctly. Anyways, after restoring the backup, TPMS is now working correctly. Thank you all for the help.
post #19 of 19 (permalink) Old 01-08-2019, 12:33 PM
JVM
Year: 2019
Engine: 3.5L Cyclone V6
Just as an FYI for the group, the TPMS light on the dash will light when any tire pressure drops 25% below placard. So if placard is 34 psi, the TPMS light will come on if pressure drops below 26 psi.
Also, you can use a rule of thumb of 1 psi drop for every 10 degree drop in temperature. So if you're on the edge, a cold morning could trip the light, but then it may go out as you drive & heat up the tire (which increases the pressure).
Finally, in regard to Jaeden possibly breaking a sensor, the light would blink for about 90 seconds at start-up if there was a communication problem between a sensor and the on-board receiver. This is something to keep in mind for the older vehicles as the sensor batteries may be coming to the end of their service life. The light will flash at start-up when a sensor battery gives up can no longer transmit a signal to the car. In this case, the sensor needs to be replaced (can not replace just the battery), and always relearned to the vehicle.
Let me know if you have any questions on TPMS.
JVM is offline
Let's talk TPMS and snow tire swap... d3500ram&taurus 5th and 6th Gen Engine and Drivetrain 13 11-29-2018 10:35 AM
Power antenna suddenly stopped working azure Maintenance and Repair 7 01-26-2017 07:41 PM
TPMS info (tire warning light), sensors, and training behlinla 5th and 6th Gen Aesthetics, Interior, Wheels and Tires 2 11-16-2014 08:53 PM
AC and rear defrost not working after factory radio reinstall Taranataurus rex Maintenance and Repair 11 10-16-2014 05:58 PM
Speedomter, Tachometer, and Trip and Engine Mileage not working.. HELP PLEASE user9797 Maintenance and Repair 20 11-28-2013 01:12 AM
