Upper Ball Joints? - Page 2 - Taurus Car Club of America : Ford Taurus Forum
 6Likes
post #11 of 13 (permalink) Old 07-10-2019, 07:17 PM
gamefanatic's Avatar
Did you replace subframe connector bushings? Common symptom when going over a bumb, like a speed bump or driveway curb, is a clunk noise from the floor. Typically it is the rears, the ones closest to your feet, but can also be the fronts.
Saved by the Cross! Bled by a Taurus...
Vulcan I - '97 Silver Taurus GL
Vulcan II - '97 Forest Green Taurus GL
Vulcan III - '02 Tan Sable LS
SHO-HIS-Love - '96 Medium Willow SHO
SHO-Foo - '96 Medium Willow SHO
gamefanatic is offline
post #12 of 13 (permalink) Old 07-11-2019, 09:44 AM
Year: 2004
Originally Posted by AngelArs View Post
I just replaced most of my front suspension, however I still hear and feel "a noise" when I hit certain types of bumps. I've had the car for a long time and this noise has always been there. Since pretty much everything else is new, I think it's a upper ball joint, but I couldn't find any videos which talk about them so I'm not sure. It's coming from the drivers side.
How should I test to see if the upper ball joint is bad?
How hard are they to replace?
Could you give us a quick rundown of what's been replaced so far? I suspect sway bar bushings or endlinks but if they've been replaced recently then that rules those out.
Kevin
Current stable
2004 Sable LS Prem DOHC
2003 Taurus SES Vulcan
2002 Taurus SES DOHC
Retired:
2001 Taurus SES DOHC
2000 Taurus SE Vulcan
1994 Sable GS
1988 Taurus LX
Hornswaggle is offline
post #13 of 13 (permalink) Old 07-12-2019, 08:16 PM
Year: 1999
Yes, would be nice to know all the components that you replaced. The stabilizer links are usually the culprit. That is the cheapest and easiest part to replace, and therefore, the first place you should be looking for the problem.
Skyjack349 is offline
Are my ball joints bad. rusty95 Suspension, Handling and Brakes 4 10-29-2015 08:55 PM
2001 Taurus Control Arms and Ball Joints Replacement Experience Automender12345 Maintenance and Repair 24 06-03-2014 09:59 PM
How long would a pair of lower ball joints last? procter Suspension, Handling and Brakes 15 11-14-2013 07:52 PM
Can bad ball joints "THUMP" when turning? azure Maintenance and Repair 2 11-11-2013 08:44 AM
Knurled Ball Joints... Any issues? coachjfk Suspension, Handling and Brakes 0 08-20-2013 01:17 PM
