Integral strut /spring assembly - Taurus Car Club of America : Ford Taurus Forum
 11Likes
post #1 of 17 (permalink) Old 03-31-2019, 09:41 AM Thread Starter
Year: 2000
Model: Ford Taurus Wagon
Integral strut /spring assembly ( Quick Struts)
Hi all. Looks like I need to replace my rear strut/spring assemblies. They are sagging to the point that the fender well is near the top of the rear tire. They are not making any noise. Can you tell me which brand is your favourite? Iíd like them to last at least 50,000 miles. Is Ford the best way to go? Iím thinking Iíll order them from Rock Auto which seems to me is the best deal around when shipping to Canada. Itís for my 2005 Taurus with 75,000 miles. Thanks.
Spock
Spock is offline
post #2 of 17 (permalink) Old 03-31-2019, 09:57 AM
KYB.
kekaye56 likes this.
sheila is online now
post #3 of 17 (permalink) Old 03-31-2019, 10:03 AM
Year: 2004
I installed a set of Monroe quick struts (#171616) on the rears and all I can say is they suck! They lose their dampening action in cold weather...which in MN is 4-5 mos out of the year. Was just thinking last evening how bad they rode compared to the originals with 240K miles on them that I replaced due to a broken spring.
MERCrunner is offline
post #4 of 17 (permalink) Old 03-31-2019, 10:40 AM
Year: 2017
Engine: 3.5L Cyclone V6
I installed quick struts on my 06 500. Big mistake, took it in for an alignment right after and the tech told me the bearings were bad. I came home, disconnected the tie rod and you could hear and feel the bearings popping. Had to remove struts, disassemble, buy new bearings and reassemble. Defeated the whole purpose of using "quick struts". I believe I also used Rock Auto due to price. Next time its just new struts and bearings for me. BTW, the bearings I removed looked brand new and the grease was clean. I can only assume it sat on the shelf too long.
kekaye56 is offline
post #5 of 17 (permalink) Old 03-31-2019, 12:40 PM
KYB are great. Install two sets of Monroe and one set KYB on my three Taurus.
Automender12345 is online now
post #6 of 17 (permalink) Old 04-03-2019, 07:55 AM Thread Starter
Year: 2000
Does anyone know if the KYB’s come with new sway bar links? Thanks. Spock.
Spock is offline
post #7 of 17 (permalink) Old 04-03-2019, 08:58 AM
The White Falcon's Avatar
Year: 2010
They donít. I recommend Moog Problem Solver links.
james27613 and RLW001xxx like this.
The White Falcon is offline
post #8 of 17 (permalink) Old 04-03-2019, 09:24 AM
Spock
Rear links are simple and basic. Cheap too. Old ones rust in two.
New Monroe struts are about like OE at 150K as to damping. Bouncy. I changed out due to broken rear spring.
post #9 of 17 (permalink) Old 04-03-2019, 09:37 AM
In my opinion the Moog problem solver links for the rear struts cause more problems than they solve. I am basing that on experience five plus years ago. They are a one piece design vs. the tube and straight thru bolt. The one piece has to be machined to go from the thick separator piece to the threaded portion. Years ago this was a sharp transition and both of the ones I installed snapped a year or so at that transition. Also since they are one piece the installation is much harder to get the swaybar to strut space to insert it. You have to do both at the same time and both sides jacked up together.
Just my experience and opinion.
post #10 of 17 (permalink) Old 04-03-2019, 10:49 AM
AC Delco, less than $7 on RA.
Easy to put on compared to nut on each end. It ain't rocket science.
Clunking noise with Strut New Assembly :( asax Suspension, Handling and Brakes 23 06-12-2017 10:04 PM
98, how to place strut back into hub/wheel assembly fishface Suspension, Handling and Brakes 19 04-27-2015 11:18 AM
Anatomy of a Strut Assembly...? azure Maintenance and Repair 5 08-08-2014 02:43 PM
Rear tension rod 99shoTaurusNewb Suspension, Handling and Brakes 8 03-03-2014 12:18 PM
Complete Front Pair Strut Quick Assembly Question? Turboman Suspension, Handling and Brakes 9 01-24-2014 07:56 PM
