'02 SEL 24V: PWR Windows, Key Fob Issues - Taurus Car Club of America : Ford Taurus Forum
post #1 of 7 (permalink) Old 05-15-2019, 12:38 PM Thread Starter
HighDesertSable's Avatar
Year: 2002
Model: Ford Taurus Wagon
'02 SEL 24V: PWR Windows, Key Fob Issues-Module??
Hello!
'02 Taurus SEL wagon w/ 24v Duratec. For a while now, the pwr windows will not work for the first 3-4 min of driving. Second issue: Memory is getting shorter w/ the key fob. It was at about 2 weeks, then I would have to reprogram it...now it's down to only several hours, and the fob will no longer work.
My mechanic told me that it is most likely an electronic module in the driver's door...does this sound right? Is this the GEM module, or is that something different?
Thank you much in advance! Dave
HighDesertSable is offline
post #2 of 7 (permalink) Old 05-15-2019, 03:57 PM Thread Starter
Year: 2002
I did some checking around the forum, and the P/N seems to be 2F1T-14B205-CB.
If any of you recommend that I find one of those to replace my own, I will be on it.
Thank you!
post #3 of 7 (permalink) Old 05-15-2019, 04:14 PM
Originally Posted by HighDesertSable View Post
Hello!
Short battery life in key fob likely a stuck key in the fob. If that fob is talking to the car all the time it may be messing thins up. I would take the battery out of the fob and see if the car works better.
chartmaker is online now
post #4 of 7 (permalink) Old 05-15-2019, 04:34 PM Thread Starter
Year: 2002
I see what you mean. I can't rule that out. Buttons seem to bounce back out. I did replace the fob battery once.
I will try removing the battery, and see if the window issue goes away...
Thank you much, dave
post #5 of 7 (permalink) Old 05-15-2019, 04:38 PM
These cars are noted for breaking wires in the accordion from the door to body. I have had 3 do that. Windows, speaker, door locks. You can move the accordion while idling the car and see if makes difference.
Got pics if you need to fix the wire.
post #6 of 7 (permalink) Old 05-15-2019, 04:59 PM Thread Starter
Year: 2002
That makes sense. That would explain why the rear speakers stopped working (it's a wagon, btw) though both stopped at the same time.
Thank you! Dave
post #7 of 7 (permalink) Old 05-15-2019, 09:06 PM
Thank you! Dave
I can only show my experience, not so common but it happens.
2000 Taurus - Intermittent Power Windows crush3r Maintenance and Repair 16 06-16-2019 01:08 PM
2000 Taurus SE - Intermittent Power Windows crush3r Electronics, Security, Audio and Visual 12 03-24-2019 01:32 AM
What grinds your gears? Ben Community 3354 07-06-2018 04:46 PM
Sable '99 Electronics [Wipers, Windows, Guages, ETC.] GEM Issues? Victoly Maintenance and Repair 5 05-30-2018 06:39 PM
Power Windows Issues frohme 5th and 6th Gen Maintenance and Repair 2 08-24-2014 01:47 PM
