Weak battery/alternator (2006)? - Page 2 - Taurus Car Club of America : Ford Taurus Forum
 3Likes
post #11 of 12 (permalink) Old 04-03-2019, 06:25 PM
Year: 1999
Model: Ford Taurus Wagon
Poor electrical ground can cause this.
Clean your battery terminals and the cable clamps. Also clean the short ground cable that is attached to the inside of
the engine compartment to the battery.
james27613 is offline
post #12 of 12 (permalink) Old 04-03-2019, 09:24 PM
Might I add? See pic, the ground is clamped over paint and rust. Look below and see this eyelet. It is the ground (return) for all the sensors on the engine. I got into this as I had erratic idle speed. The TPS sensor had 5V on one leg, solid but the ground was wandering around so the sensor had erratic position signal. Problem fixed. Location on the firewall pas side.
You can fix this without effecting the PCM memory.
Gen1 start is weak and car has lost a lot of power. Please help. craigtussey Introduction Forum 4 02-05-2019 03:14 PM
2013 Taurus - blower airflow seems weak UKfordguy 5th and 6th Gen Maintenance and Repair 5 10-18-2018 04:22 PM
98 Sable Aftermarket Radio - Weak Radio Signal - Scosche Kit JWGarber1725 Electronics, Security, Audio and Visual 8 12-12-2014 06:47 PM
Horn sounding weak NyteFire Electronics, Security, Audio and Visual 13 11-10-2013 01:31 AM
Random stalling. Restarts with weak idle. blickcd Engine and Drivetrain 15 05-14-2013 08:19 PM
