Display on instrument cluster - Page 2 - Taurus Car Club of America : Ford Taurus Forum
 4Likes
post #11 of 11 (permalink) Old 02-13-2019, 12:56 PM
AngelArs's Avatar
Year: 2004
Lightbulb
Originally Posted by jkfde View Post
I noticed if I dim everything super low, it goes bright for a split second...
There are only so many things that could be causing this. The most likely issue is something to do with the dimmer switch (it's going bad, dirty contacts or similar). There is also a main electrical feed right behind the dash which might be coming loose, has a wire pinched, bad ground or similar, but if it was this you should be showing other instrument issues. A previous owner of the car might have also rewired something, so don't rule that out, especially since it's been like this since you've bought the car. Would need more information to diagnose further.
AngelArs is offline
'04 Instrument cluster replacement Hornswaggle Maintenance and Repair 4 03-08-2017 10:14 AM
Instrument Cluster Display Quest. Jim1969 Maintenance and Repair 9 07-10-2015 07:04 AM
Center information display on instrument cluster quits antibiotics Maintenance and Repair 7 02-09-2014 12:41 PM
2004 Taurus Instrument Cluster Swap mbellaire Electronics, Security, Audio and Visual 8 09-13-2013 01:00 PM
Diagnosing an electronic instrument cluster problem 1992 Sable wnlewis Electronics, Security, Audio and Visual 3 05-29-2013 01:33 AM
