99 Taurus Electrical Problems - Taurus Car Club of America : Ford Taurus Forum
 1Likes
  • 1 Post By Kevo02
post #1 of 10 (permalink) Old 05-24-2018, 12:23 PM Thread Starter
Year: 1999
I have a 99 Taurus with a Duratec engine. I am having problems with the cooling fans and blower fan in my car. it started when my A/C compressor burned up due to running with no freon. Replaced compressor with bypass pulley so I can use same belt. The problem is that now my cooling fans do not work properly, also climate controls including blower fan inside do not work. Checked both the blower and cooling fans by jumping them, both work fine. The only way I can get the cooling fans working is to disconnect one of the wires to the coolant temp sensor, however both fans run constantly when car is running. The blower is working because I hot wired it to a toggle switch, also that is the only way my climate controls will work. Once thought it was head unit with EATC, replaced with 3 other units still same problem. Looking under hood in relay box I noticed that the plug where the A/C clutch relay is plugged is burnt, also it will blow relays about once every other month, I have to get extras when I have to go to junkyard in order to have one when the next one blows.I can do without A/C for now but I cannot keep going with these problems, I am afraid that I will kill my engine if I do not do anything!! Is there someone out there that can help me with this problem, if it is a wiring problem, please point me in the right direction. I love my Taurus and I don't want to lose it!!! Have had the car since 2005 with 64K miles and now I have over 250K miles on it and it's still going strong and I want to drive it until the tires fall off.Thanks, Kevo02
Kevo02 is offline
post #2 of 10 (permalink) Old 05-24-2018, 01:39 PM
Not your year but the A/C relay goes to 2 things. The clutch coil and a diode. In this case the relay needs to be removed. It does nothing but feed 2 things you do not need. If in your year it does something else also, you need to be sure the wire to the A/C coil is not hooked to anything or shorted as well as the diode.
post #3 of 10 (permalink) Old 05-24-2018, 02:23 PM Thread Starter
Year: 1999
Does not apply to my car, it also controls the radiator fans, when the relay goes bad the fans will not work and engine overheats
Kevo02 is offline
post #4 of 10 (permalink) Old 05-24-2018, 10:36 PM
Play Nice or Don't Play
jag1959's Avatar
Engine: 3.4L Yamaha V8
After making sure the wires and connector to the compressor aren't shorting you can check the wiring diagrams for your year for points of commonality by using this site:
BBB Industries- Premium Alternators, Starters, Power Steering Products | TSB's & Wiring Diagrams
It's SHO time!
jag1959 is offline
post #5 of 10 (permalink) Old 06-28-2018, 11:56 AM Thread Starter
Year: 1999
I think I need to start with the remote climate control module (RCC), where is it and also the blower motor relay, I have automatic climate control. This may be the reason my blower doesn't work.
Kevo02 is offline
post #6 of 10 (permalink) Old 06-28-2018, 12:57 PM Thread Starter
Year: 1999
Also, I think there may be a bad connection Between Integrated Control Panel and Remote Climate Control Module that is keeping blower from operating, is it possible?
Kevo02 is offline
post #7 of 10 (permalink) Old 06-28-2018, 10:29 PM
Rcc module connects to the blower fan. Iirc, under dash/glovebox.
post #8 of 10 (permalink) Old 07-02-2018, 08:30 AM Thread Starter
Year: 1999
Thanks Shelia, The control panel will not operate the blower fan even though you can adjust the vents and temperature, also the unit will not allow me to self-diagnose, function does not work. but when I jump one of the wires on the blower relay module, fan comes on and diagnostic works as well.
Kevo02 is offline
post #9 of 10 (permalink) Old 06-13-2019, 11:04 AM Thread Starter
Year: 1999
Thanks Sheila,
I found the problem, it was the remote climate control module, a circuit inside burned out. Replaced it with one from JY, works just fine now.
Kevo02 is offline
post #10 of 10 (permalink) Old 06-13-2019, 11:12 AM Thread Starter
Year: 1999
Still have problem with cooling fans, still blowing relays for some reason, for now I have unplugged the coolant temperature sensor which makes both fans run constantly while car is running, and does not blow relays.
Kevo02 is offline
2008 taurus suspension problems ronoharold 5th and 6th Gen Suspension, Handling and Brakes 12 09-04-2017 09:24 AM
Sputter on start up breeder15 Maintenance and Repair 21 01-01-2017 12:17 PM
2002 Ford Taurus 3.0 - Electrical Short Slippery_Petes Maintenance and Repair 10 12-01-2016 05:12 PM
Electrical problems on my 2001 taurus A_wycoff Maintenance and Repair 16 03-25-2014 08:33 AM
You may post new threads
You may post replies
