1997 ford taurus station wagon antenna repair - Taurus Car Club of America : Ford Taurus Forum
post #1 of 7 (permalink) Old 08-01-2014, 03:00 AM Thread Starter
anybody have a link to a good write up (preferably with pictures) on how to repair a power antenna? i have the parts kit just wanted to make sure I do it right the first time.
Thanks!
David
coggonobrien is offline
post #2 of 7 (permalink) Old 08-01-2014, 09:41 AM
Are you just replacing it or taking it apart and repairing it?
2003 Mazda Protege5, 2.0L (Daughter #1)
2008 Nissan Titan SE, Crew Cab/Long Bed, 5.6L (Mine)
2007 Volvo V70 2.5T, turbo 2.5L (Mine)
2010 Mazda 6 Grand Touring, 2.5L (Daughter #2)
2012 Toyota Camry LE, 2.5L (Wife)
Exocet is online now
post #3 of 7 (permalink) Old 08-01-2014, 09:44 AM Thread Starter
repairing
post #4 of 7 (permalink) Old 08-01-2014, 10:25 AM
don2775's Avatar
When I did mine I took apart the unit, removed the broken plastic pieces, had a replacement antenna in hand (got one of eBay), had someone turn on the radio then off, when the motor was running I fed the plastic cable in. It will stop when it's fully retracted. BINGO.. new antenna!
don2775 is offline
post #5 of 7 (permalink) Old 08-05-2014, 02:20 AM Thread Starter
did you have any trouble removing the old antenna? from what I understand when i removed the nut on the outside of the car and the plastic shroud it should pull right out as the motor is running but my seems to be seized.
post #6 of 7 (permalink) Old 08-05-2014, 05:19 AM Thread Starter
i removed the body of the antenna from the car, opened it up and found the plastic teeth tape from the mast was coiled perfectly but broke clean. took it out no loose pieces and the sprocket teeth were in perfect shape. the problem is that the mast will still not pull out. is it threaded or something wierd?
post #7 of 7 (permalink) Old 08-05-2014, 02:24 PM
don2775's Avatar
Don't think so maybe it's just stuck, you might try some lithium grease or wd-40 on it, let it set a few and try again, it should come out clean.
If it gives you too much trouble it might be a good idea to go to your local yard and get another motor unit, it might even have a good antenna too!!
don2775 is offline
Ford Needs to Make a Station Wagon unit731 Taurus and Sable General Discussion 134 02-17-2014 04:22 PM
What to Grab before Scrapping 1997 Ford Taurus GL Wagon saturninin Taurus and Sable General Discussion 6 12-13-2013 10:37 PM
The Historic '03 Red Wagon DLC360 Taurus and Sable Project Log 20 06-24-2013 09:57 PM
