2000 Taurus SE - Intermittent Power Windows - Page 2 - Taurus Car Club of America : Ford Taurus Forum
 3Likes
post #11 of 13 (permalink) Old 09-18-2018, 11:04 AM
Year: 02
Most likely there is a break of the wire inside the insulation. Years of flexing work hardens copper and it cracks, causing an intermittant open in the circuit. Put tension on each wire one at a time until you find the culpret. Cut the insulation at the break and splice the wire and solder.
rsteve56 is offline
post #12 of 13 (permalink) Old 09-18-2018, 10:55 PM
When the fault occurs, check to see if tapping any of the relays on the underdash fuse box, and junction box to see if that brings any function back.
Precision Transmission is offline
post #13 of 13 (permalink) Old 03-24-2019, 01:32 AM
ChesPiece's Avatar
Crush3r, howre things going with your car? I'm currently going through the same with my 03. It's definitely getting frustrating. So far, if I wiggle the wires under the fuse panel in the 24 pin connector it'll ding and the windows and lights will work. I don't know, I hope you had some luck with yours.
ChesPiece is offline
2000 Taurus - Intermittent Power Windows crush3r Maintenance and Repair 13 10-15-2013 07:14 PM
2000 3.0 Vulcan Taurus Power Steering Lincoln612 Maintenance and Repair 10 05-30-2013 11:28 PM
