90-04 Wiring Diagram Information - Page 2 - Taurus Car Club of America : Ford Taurus Forum
Closed Thread
post #11 of 22 (permalink) Old 07-05-2008, 12:18 PM
I need the wiring diagram to a 97 ford taurus for the A\C Heater and the other functions for the climate control
timeout is offline
post #12 of 22 (permalink) Old 10-28-2008, 04:19 PM
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery WHITE/RED (+) RADIO HARNESS
Accesory BLACK/PINK (+) RADIO HARNESS
Ground BLACK OR BLACK/YELLOW (-) RADIO HARNESS
Illumination DK BLUE/WHITE
LF Speaker (+) ORANGE/LT GREEN
LF Speaker (-) LT BLUE/WHITE
RF Speaker (+) WHITE/LT GREEN
RF Speaker (-) DK GREEN/ORANGE
LR Speaker (+) GRAY/LT BLUE
LR Speaker (-) TAN/YELLOW
RR Speaker (+) ORANGE/RED
RR Speaker (-) BROWN/PINK
Amp Location DRIVERS SIDE SHOCK TOWER IN TRUNK ON SEDAN'S OR STATION WAGON BEHIND PARE TIRE
Radio Security YES
Security
Battery LT GREEN/PURPLE (+) IGNITION HARNESS
Ignition 1 RED/LT GREEN (+) IGNITION HARNESS
Starter 1 RED/LT BLUE (+) IGNITION HARNESS
All Door Trigger BLACK/BLUE (+) DRIVERS KICK OR SJB TOP PLUG PIN#22
YOU MUST DIODE ISOLATE ALL TRIGGERS TO MONITOR ALL DOORS.
LF Latch YELLOW/BLACK (-) EACH KICK PANEL OR AT GEM MODULE 26 PIN PLUG PIN 5
RF Latch GRAY/RED (-) EACH KICK PANEL OR AT GEM MODULE 26 PIN PLUG
pIN 19
LR Latch LT GREEN/YELLOW (-) EACH KICK PANEL OR AT GEM MODULE 26 PIN PLUG pIN 20
RR Latch PINK/BLACK (-) EACH KICK PANEL OR AT GEM MODULE 26 PIN PLUG PIN 7
Trunk Trigger BLACK/PINK (-) EACH KICK PANEL OR AT GEM MODULE 26 PIN PLUG PIN
Hood Trigger TAN/LT GREEN (-) EACH KICK PANEL OR AT GEM MODULE 26 PIN PLUG PIN 17
Alarm Disarm PINK/WHITE (+) DRIVERS KICK OR AT GEM MODULE 26 PIN PLUG PIN#4
Alarm Arm ARMS WITH LOCKS
Parking Lights BROWN (+) AT SWITCH OR SJB BOTTOM PLUG PIN #31
Convenience
Headlights-Lo RED/YELLOW (+) AT SWITCH OR SJB MODULE BOTTOM PLUG PIN#31
All Hazrd Lights BROWN
Wipers-Lo DK BLUE/ORANGE (-) AT SWITCH OR GEM MODULE 20 PIN PLUG PIN #3
Parking Brake LT. GREEN (-) AT SWITCH OR GEM MODULE 26 PIN PLUG PIN#1
Trnk Release PURPLE/YELLOW (-) AT SWITCH OR GEM MODULE 26 PIN PLUG PIN# 3
Remote Start
Ignition 2 BLACK/LT GREEN (+) IGNITION HARNESS
Accessory 1 GRAY/YELLOW (+) IGNITION HARNESS
Anti-Theft Type FORD PATSĀ® OR SECURILOCKĀ® VEHICLE IMMOBILIZER
WHEN CONNECTING FLASHLOGIC BYPASSES: RX AND TX WIRES ARE AT 4 PIN CONNECTOR ON KEY SWITCH, THEY ARE: WHITE/LIGHT GREEN (TX) AND GREY/ORANGE(RX)
Anti-Theft Descript TRANSPONDER
Key Sense BLACK/LT GREEN (+) IGNITION HARNESS OR GEM MODULE 20 PIN PLUG PIN#17
Tachometer UNCOMMON FUEL INJECTOR WIRE (-) AT MODULE ON FIREWALL - PIN #48
Speed Sense GRAY/BLACK (AC) AT PCM PIN 68
Brake Lights RED/LT GREEN (+) AT BRAKE SWITCH
Reverse Lights BLACK/PINK (+) DRIVERS KICK PANEL HARNESS TO REAR
Horn DK BLUE (-) AT SWITCH OR SJB BOTTOM PLUG PIN1
Modules
WIRE LOCATION
Module 1 GEM MODULE IS PART OF THE SJM AND IS LOCATED TO THE LEFT OF THE STEERING COULUMN AND AGAINST THE INSIDE OF THE FIREWALL
Doorlocks/Windows
Door Lock Circuit 3 WIRE NEGATIVE CIRCUIT
Power Unlock PINK/GREEN (-) DRIVERS KICK OR GEM 26 PIN PLUG PIN 18
PowerLock PINK/YELLOW (-) DRIVERS KICK OR GEM 26 PIN PLUG PIN
Driver Mtr Unlock RED/WHITE (REV) DRIVERS KICK OR SJB TOP PLUG PIN 2
Driver Mtr Lock PINK/BLACK (REV) DRIVERS KICK OR SJB TOP PLUG PIN 3
Pas Mtr Unlock PINK/ORANGE (REV) DRIVERS KICK OR SJB TOP PLUG PIN 4
Pas Mtr Lock PINK/BLACK (REV) DRIVERS KICK OR SJB TOP PLUG PIN 2
LF Window Up WHITE/BLACK (REV) DRIVERS DOOR SWITCH
LF Window Dn ORANGE/WHITE (REV) DRIVERS DOOR SWITCH
RF Window Up WHITE/YELLOW (REV) DRIVERS DOOR SWITCH
RF Window Dn YELLOW/RED (REV) DRIVERS DOOR SWITCH
LR Window Up YELLOW/LT BLUE (REV) DRIVERS DOOR SWITCH
LR Window Dn GRAY/ORANGE (REV) DRIVERS DOOR SWITCH
RR Window Up YELLOW/BLACK (REV) DRIVERS DOOR SWITCH
RR Window Dn RED/BLACK (REV) DRIVERS DOOR SWITCH
wow very helpful post
piff1392 is offline
post #13 of 22 (permalink) Old 03-20-2009, 04:28 PM
Jh8909's Avatar
i need a audio wiring diagram im trying to hook up an aftermarket head unit for 95 a gl
95 Green/Green SLO, 185k, DD <-- FOR SALE!!!
92 Black/Black SHO, 148k, weekend car
Jh8909 is offline
post #14 of 22 (permalink) Old 04-21-2010, 09:26 AM
QUOTE (Jh8909 @ Mar 20 2009, 04:28 PM)
i need a audio wiring diagram im trying to hook up an aftermarket head unit for 95 a gl[/b]
Same here. I have a 2000 Sable. Has the Factoryu radio with the built in digital climate controls.
have the Mach Stereo system. One of the rear channels seems to be out so do not know if it is the head unit or the RCU the has the issue.
Jeff
SteelRyche is offline
post #15 of 22 (permalink) Old 10-07-2010, 05:01 AM
Nice information !
ashokagroup is offline
post #16 of 22 (permalink) Old 12-04-2010, 11:42 AM
Exclamation HELP!!! No Defroster.....
Thanks for posting this diagram. The one on the12volt is incorrect for acc / ign wiring.
Helped me fix my remote start
I wanted to add my rear defrost switch to a 12v output on my remote start so i was testing for the right wires @ the REAR DEFROST RELAY and i believe i had the relay IN and a pigtail coming from pin 86 on relay coil. this read 12v and as i was moving to turn the key the pigtail hit ground and i heard POP. now i figured it was the relay and i'll put another one in, no big deal. but it's not the relay.
So no defrost with a new relay. no illumintion of switch upon pressing. and no relay clicking.
finally, is there something that FEEDS the rear defrost relay upstream? if so please tell me so i can get another one or wire around it.
thanksya
safranciscotreat is offline
post #17 of 22 (permalink) Old 04-12-2011, 01:01 PM
ive got a 1998 ford taurus 3.0 v6. im trying to hook up a new stereo without a wiring harness. im having difficulty finding the wiring diagram for the mach stereo system. any help?
Jchadek is offline
post #18 of 22 (permalink) Old 02-27-2012, 12:00 PM
Exalted Grand Poobah
Lgbpop's Avatar
Year: 1990
Forgive me dredging up a dormant thread. Anyone have a diagram/image of the ignition switch wiring positions for a 1990 Taurus?
I had to replace the switch and connector last night. When I removed the old connector from the old switch, it was cracked in two pieces (overtighted mounting screw, I bet) and the white/pink wire just fell free, wasn't sure what place it came out of. It's one of two places. I'm afraid if I place it wrong I'll do some damage or blow something up.
Lgbpop is offline
post #19 of 22 (permalink) Old 02-28-2012, 11:52 AM
Lgbpop's Avatar
Year: 1990
Lucky accident, but I solved my own problem. I was wiping the scorch mark in the switch with my finger where the connector fits into and felt what seemed like dirt, but upon closer examination turned out to be raised lettering. Every terminal in the switch was marked. As I suspected, the starter wire's home was the square split in two in the old, broken connector.
Lgbpop is offline
post #20 of 22 (permalink) Old 05-20-2014, 01:20 PM
Originally Posted by taurusguy101 View Post
does this include the 04 sel, caus ei hered the sel is different form the the ses and lx wiring
I'm looking for the diagram for the 03 SEL as well. Can't find it anywhere and this diagram didn't help as I've tried it too
chiefjoel_ch is offline
Closed Thread
You may post new threads
You may post replies
