2008 Transmission Clunk! - Taurus Car Club of America : Ford Taurus Forum
 1Likes
  • 1 Post By MikeGlosta
post #1 of 1 (permalink) Old 08-11-2019, 08:04 AM Thread Starter
Year: 2008
Engine: 3.5L Ti-VCT V6
My specs:
2008 Taurus SEL 134000 K
18 mpg city; 22-24 mpg highway ( keeping it at 75-80 mph )
Problem started with hard shift, banging into D and R, then loss of power, transmission stuck in high gear.
Scan turned up OSS ( outer speed sensor ) which I then had replaced: bad location, a job I couldn't do, $500
Problem reoccurred a couple times after new sensor installed Then I realized the positive battery cable probably hadn't been disconnected during repair. I was 200 miles from home when the transmission acted up again so I disconnected the cable to clear the code. 600+ miles later the car is driving like it just came off the lot.
Hope this helps anyone with similar problem. Replace the sensor AND clear the code.
kekaye56 likes this.
MikeGlosta is offline
2008 transmission mount replacement geekwithoutacause 5th and 6th Gen Maintenance and Repair 6 07-17-2019 09:46 AM
2008 Taurus SEL Transmission Shudder Fixed! TJ SD 5th and 6th Gen Maintenance and Repair 12 10-30-2017 01:16 PM
2008 Taurus: Transmission revs between gears pr85258 5th and 6th Gen Maintenance and Repair 2 10-20-2015 11:12 AM
2008 Taurus transmission problem. Please help! TJ SD 5th and 6th Gen Maintenance and Repair 10 05-01-2015 09:47 PM
