Thick white smoke after oil change - Page 2 - Taurus Car Club of America : Ford Taurus Forum
 1Likes
post #11 of 16 (permalink) Old 06-29-2019, 02:35 PM
^^^^^ Agreed.
post #12 of 16 (permalink) Old 06-29-2019, 03:42 PM
Sounds like the turbo shaft seals are blown and that will also cause a misfire. My daughter was looking at a BMW that had a 1/4 inch thick CarFax and it had pages of misfire reports and new sparkplugs. When you started the engine it pumped out smoke, then cleared up. It was only two years old but turbo seals were bad. Oil will accumulate in the intercooler and you needed to open the throttle to blow it clean but oil goes into engine and fouls sparkplugs. If it was starting to misfire it could have been the start of a seal failure. If exhaust side seal fails then it just pours into exhaust.
I guess they only thing that could cause a massive engine failure is running engine without oil for a short period of time. How do you prove that. And not you driving it home after the smoke came pouring out. Did they have to refill the engine after they dropped the exhaust pipe to drain oil?
What is the Ford people saying other than a bad engine? Low oil pressure, knocking? Why two bad turbos? Lack of oil. Was oil light on in your car?
post #13 of 16 (permalink) Old 06-29-2019, 05:41 PM
ice445's Avatar
Yup, my Fiat's turbo has a little bit of leakage when the bearings are cold. A little bit is generally no big deal, but eventually you need to address it by rebuilding the turbo.
ice445 is offline
post #14 of 16 (permalink) Old 06-29-2019, 06:28 PM
Are the quality of turbos going down the toilet these days? The aftermarket made in the USA Garrett T3 on my 88 Tbird Turbo Coupe has over 100K miles on it, and I regularly boost it up to 24 psi with meth injection. Zero issues with the Garrett turbo since I put it on back in 2000 to replace the pathetic Warner ISHI turbo the car came with. No smoke out the tailpipes ever, and engine uses half a quart of oil every 3K miles. Engine runs better than new with 271K miles on the car.
post #15 of 16 (permalink) Old 06-29-2019, 07:31 PM
The Ford turbo are little peanut size and the scrolls are about two inches in diameter. You know the cool down and proper oil during engine shut down is critical. Spinning 50k to 150k rpms is scary to think and not have proper oil conditions. I seem to remember some turbos had preoilers and pressurized oilers to oil during spin down. Don't think Ford uses them. I think older turbos spin slower and were derivatives of turbo diesel era.
I liked turbos when I was younger but now I look at reliability and trouble free ride that can hit 200k without major influx of money. Can't see OEM turbos lasting the life of the car with those extreme rpms and temperatures.
Did GraySHO1 ever attempt an induction cleaning or did the express oil change place sell him one?
post #16 of 16 (permalink) Old 07-03-2019, 07:51 PM
KillrRABBIT's Avatar
Year: 2000
Sounds like it's burning water.
Check if someone put something in the fuel or oil. (Did you have the engine flushed and they forgot to take it out and put oil in?)
Why would you drive it out of the parking lot if you saw all that smoke after they did just an oil change?
KillrRABBIT is offline
The Tech Talk Thread jag1959 Odds and Ends 361 02-08-2018 06:41 PM
White Smoke From Engine Compartment bobdaman18 Maintenance and Repair 9 01-01-2017 08:44 PM
P0174 and White Exhaust Smoke jhromine Maintenance and Repair 2 01-16-2016 06:27 PM
Burning rubber and white smoke on alt belt NyteFire Maintenance and Repair 28 06-22-2015 01:08 PM
White smoke from tail pipe+ misfire- Please help! auto Maintenance and Repair 18 08-04-2014 02:07 AM
