3.5 head torque - Taurus Car Club of America : Ford Taurus Forum
post #1 of 5 (permalink) Old 03-14-2019, 02:12 PM Thread Starter
3.5 head torque
Hello everyone I'm replacing the water pump and head gaskets on my 2011 taurus sel 3.5 non-turbo. Got the heads off and haven't had too much luck finding what the torque specs are for the head bolts. Any idea what the sequence is as well? Also the actually head of the bolt just says "SPS" so doesn't give me a good idea of what ball park I'm in. Thank you!
GBTaurus is offline
post #2 of 5 (permalink) Old 03-14-2019, 03:39 PM
That maybe because they are tightened by stretch and not torque. You torque to a pretty low setting and they loosen then tighten to a torque but the final tightening is determined by angle of rotation and not torque. It is called torque to yield and old bolts can not be reused.
post #3 of 5 (permalink) Old 03-14-2019, 07:53 PM Thread Starter
Yes I got that. I’ve done head bolts before. Looking to know what the sequence is and what the initial torque is and then after that how far the yield roatation needs to be. 45 degrees? 90 degrees. Any information will help thanks
GBTaurus is offline
post #4 of 5 (permalink) Old 03-15-2019, 03:51 PM Thread Starter
I found some specs on the 3.5 ecoboost motor. Do those apply to the NA 3.5? Gonna try and put them back on today so might be finding out the hard way whether it's right or wrong lol. Thanks
Name:	Capture 2_1552682993363.JPG
GBTaurus is offline
post #5 of 5 (permalink) Old 03-15-2019, 03:54 PM Thread Starter
Some more of the thread I found the specs on -
ID:	208115   Click image for larger version
GBTaurus is offline
92 3.8 Head bolt order and torque punky482 Maintenance and Repair 1 09-09-2017 12:58 PM
Blown Head Gasket - Should I replace the Cylinder Heads? mdtobe Maintenance and Repair 11 08-18-2016 01:03 PM
Good torque range for 3/8" torque wrench? q0987 Maintenance and Repair 9 02-19-2014 04:20 PM
Torque mount on duratecs (gen 4)? curiosul Engine and Drivetrain 11 06-10-2013 09:00 PM
