2008 Taurus X - P0446 - killin' me - Taurus Car Club of America : Ford Taurus Forum
post #1 of 2 (permalink) Old 02-16-2019, 03:24 PM Thread Starter
nevinnh's Avatar
Year: 2008
Model: Ford Taurus X
I posted this before but put it in the Intro forum - oops.
I'm getting just the P0446 - no other codes.
I've checked the gas cap and tried a second one from a different car.
I've pulled the canister and tested the vent valve on the bench. Canister looks clean and fittings were tight, hoses look good.
I can't see the fuel filler pipe connection to the tank - hope that is not it.
I've removed and tested the purge solenoid on the bench. Fittings/hoses look good.
Chased the hoses from front to the canister and they look good.
I created my own (crude) smoke machine and stuck it in the tube at the intake and plugged the intake hole (so, the car would not die). I found no leaks but I'm not sure if this was the right way to do a smoke test. I had the engine running which I think would open the purge valve and force the smoke back to the canister. Is that the right way.
I fear the problem is the ECM signal wiring and I'm not sure how to troubleshoot that.
Any help is much appreciated.
Thanks, Bill
nevinnh is offline
post #2 of 2 (permalink) Old 03-01-2019, 01:38 PM Thread Starter
nevinnh's Avatar
Year: 2008
I've learned a little more on this issue. The vent valve works fine on the bench. I have 12V at the vent valve connector on the canister. My mechanic can command the PCM to try to control the vent valve but it does not open/close. So, the problem is in the ground wire back to the PCM. I cannot chase it back to the PCM since it is buried in a cable harness to the PCM.
The million dollar question is does anyone know what terminal on the PCM this ground wire from the vent valve is landed?
Thanks,
Bill
nevinnh is offline
2008 taurus suspension problems ronoharold 5th and 6th Gen Suspension, Handling and Brakes 12 09-04-2017 09:24 AM
2008 Ford Taurus SEL Chrome Hood Protector MysticMan Taurus and Sable General Discussion 1 05-20-2017 02:37 PM
2008 Taurus blower motor only working on high mrthinkshesfunny 5th and 6th Gen Maintenance and Repair 2 06-29-2015 07:22 PM
Which Car Should I buy ??? 08FordTaurusSedan Taurus and Sable General Discussion 11 01-12-2015 01:31 AM
wheels from a 2010 taurus fit a 2008 Taurus? eckell3 5th and 6th Gen Aesthetics, Interior, Wheels and Tires 1 10-28-2013 09:28 PM
