13+ motor swap in a 10-12 Taurus - Taurus Car Club of America : Ford Taurus Forum
 2Likes
post #1 of 11 (permalink) Old 02-12-2019, 06:09 PM Thread Starter
Hi I have a 2011 Taurus Sel with 310xxx miles and a blown head gasket. I’m looking to just replacing the entire engine rather than rebuilding it. I have found a lot of 13’ model year engines and beer of the 3.5 and was wondering if that would work in my 2011? Any thoughts if that’s a possibility without our too much tweaking? Thanks
GBTaurus is offline
post #2 of 11 (permalink) Old 02-12-2019, 09:20 PM
The White Falcon's Avatar
Year: 2010
Engine: 3.5L Cyclone V6
Bigger hassle than it's worth. 2013+ is when they went to TiVCT and made other changes.
The White Falcon is offline
post #3 of 11 (permalink) Old 02-12-2019, 10:06 PM
AdmiralSparklez's Avatar
Year: 2013
Hey, nothing is impossible. I'm sure it would fit, but the electrical architecture and the module network would probably get really upset. I'd recommend sticking with a 3.5 from the 2010-2012 years.
UKfordguy likes this.
AdmiralSparklez is offline
post #4 of 11 (permalink) Old 02-13-2019, 12:32 AM Thread Starter
Ok that’s what I was figuring. Thanks for the responses! Just gonna look for an engine between those years. I’ve heard a lot of bad things about the water pumps going out often on these. What’s the mileage I should be aware of when getting an engine. Probably best just to change out the pump while I have the engine out of the car
GBTaurus is offline
post #5 of 11 (permalink) Old 02-13-2019, 07:55 AM
UKfordguy's Avatar
Year: 2013
Engine: 3.5L EcoBoost V6
Find the lowest mileage engine you can find, and still change out the water Pump. I think around the 85k miles + is the time the pump could fail or maybe a little later (mileage wise). Either way may as well change out the pump whilst the engine swap is being done.
2013 Taurus SHO with Performance Package: Air Raid Cold Air Intake: Magnaflow twin pipes with performance mufflers: De-baged. SCT X4 93 Canned Tune,( 3bar map sensor, 170 thermostat, gapped plugs to be installed), smoke tint headlights
Other rides:
- 1993 Kawasaki ZX7
- 1988 Dodge Dakota 3.9 V6 5sp RWD - restored
UKfordguy is offline
post #6 of 11 (permalink) Old 02-13-2019, 07:57 AM
UKfordguy's Avatar
Year: 2013
Hey Admiral, don't mean to hijack this thread, but a user could use your advice/expertise
https://www.taurusclub.com/forum/117...-possible.html
AdmiralSparklez likes this.
Other rides:
- 1993 Kawasaki ZX7
post #7 of 11 (permalink) Old 02-13-2019, 10:27 AM
Year: 2013
So just out of curiosity, is the water pump something that WILL fail/leak or something that fails more often than not in these vehicles and a lot of us will actually be fine? Because after looking up how to replace it thinking it was easy, my anxiety rose at an alarming rate as I witnessed the engine being removed from the car and the timing components being removed to access the pump. Please Lord tell me my car will not nuke it's own coolant pump.
post #8 of 11 (permalink) Old 02-13-2019, 10:43 AM
UKfordguy's Avatar
Year: 2013
Well I had a 2010 SHO with over 110k miles and had no issues with the water pump and so far my 13 is ok with 84k miles and all is good. It's not something that WILL fail, however if it does it can be catastrophic and if not caught in time it will mean a new engine. There are few users on here who have unfortunately suffered water pump failure.
My dealership quoted me $1300 for the replacement (that was with a little discount too). I was just curious, there is a user on here who did the job himself and he said it's a big job for sure. Damn internal water pumps....a la Chrysler 2.7's!
Other rides:
- 1993 Kawasaki ZX7
post #9 of 11 (permalink) Old 02-13-2019, 10:46 AM
Year: 2013
Yeah it's not something I think I could tackle. I'm nearing 81k with no issues that I know of. At that point if the engine is out of the car, I'll just force a 5.0 or a 5.2 voodoo in the car like I've always dreamed of doing (I'm not kidding). Are there any signs or symptoms of pump failure to watch out for to tell whether or not it's time?
post #10 of 11 (permalink) Old 02-13-2019, 11:25 AM
UKfordguy's Avatar
Year: 2013
With the pump being internal, rarely will you see any drops of coolant etc.as it leaks internally. However you may have loss of heat and car temp creeping up. If that happens I'd stop the car right there and get it towed so's not to cause engine failure. You can have your oil analysed too to see if their is any contamination (such as coolant) I believe
I did request a kit from a US company to obtain oil samples for them to test months back, but never received it (free). I will need to follow up with them.
Other rides:
- 1993 Kawasaki ZX7
Spark Plugs unit731 Engine and Drivetrain 19 06-18-2018 01:30 PM
Ford Taurus Fog Light LEDs! Plug & Play Install! Same-day Shipping! USA Made SLF! Diode Dynamics Diode Dynamics 10 04-30-2018 05:50 PM
The Tamaro or I call her Sinnamon: A True Transformation!!! Tamaro Taurus and Sable Project Log 41 04-24-2018 04:11 PM
Ford Taurus Reliability - Better Info mkaresh Taurus and Sable General Discussion 73 11-21-2016 01:46 PM
New member, 2nd Taurus, 4th Ford, former GM'er Rob Lee Introduction Forum 11 06-06-2014 09:57 AM
