Intermittent A/C - Page 2 - Taurus Car Club of America : Ford Taurus Forum
 3Likes
post #11 of 17 (permalink) Old 06-08-2019, 09:41 PM Thread Starter
Year: 2010
Model: Lincoln MKS
Engine: 3.5L EcoBoost V6
I had my blower manually cranked to the highest setting this time around. While I don't remember exactly, it's entirely possible that my blower speed was on the low to medium settings during the first data log, but both times the climate system was set to "MAX A/C." It seems to me that MAX A/C should crank the blower to max, but my climate control system never wants to bring the blower speed above 50% automatically, and anything above that has to be manually adjusted. Does this sound like a failure of some sort?
Schlotzky is offline
post #12 of 17 (permalink) Old 06-09-2019, 10:09 AM
Year: 02
I think that is normal automatic operation. Testing should be done in manual mode, max cool, high blower, doors open.
rsteve56 is offline
post #13 of 17 (permalink) Old 06-10-2019, 10:13 PM Thread Starter
Year: 2010
Model: Lincoln MKS
Well, after all this troubleshooting effort, it's turns out the system was just overcharged. I drove about 90 minutes away in 90 degrees stuck in traffic, and when I got there I decided to grab a screwdriver and just engage the Schrader valve in the chance that I could just get it to engage the compressor at all. Two good purges and the compressor engaged and stayed engaged. It was acting up again on the way home from work, with temperatures getting up to 97 degrees, so I let out a bit more pressure and the compressor kicked back on and stayed on to blow icy cold air in the sun. I'm now running 30ish psi on the low and 250psi on the high in 95 degrees, which seems a lot more reasonable. I also noticed that the radiator fans kicked down in speed after letting some pressure off, and the "auto" fan actually went all the way up to full blast in "max a/c mode". Apparently it's all connected!
Thanks for the help, guys!
Omar Ameen likes this.
post #14 of 17 (permalink) Old 06-11-2019, 10:22 AM
How did it get overcharged?
post #15 of 17 (permalink) Old 06-12-2019, 02:53 PM
Year: 02
Don't ask, he might just vent more to the atmosphere! Rookies!
kekaye56 likes this.
rsteve56 is offline
post #16 of 17 (permalink) Old 06-13-2019, 04:10 AM
ice445's Avatar
Yeah I would have preferred OP take it to a professional to get manifold readings instead of just venting to atmosphere and calling it fixed.
ice445 is offline
post #17 of 17 (permalink) Old 06-13-2019, 10:11 AM Thread Starter
Year: 2010
Model: Lincoln MKS
When I first popped the cap off, I noticed that it appeared the system had UV dye added to it at some point, so I suppose it was overcharged when I purchased the car second hand.
And don't worry guys, I'll capture a few cow farts to make up for my horrible travesty of venting an ounce or two, and take all my old vehicles that are at risk for leaks to preemptively have all their refrigerant evacuated and tell all my friends to do the same. 👍
2007 ford taurus intermittent stalling and intermittent rough idle. Stephen Pump Maintenance and Repair 50 05-20-2019 07:37 PM
Intermittent No-Crank ForrestBob Maintenance and Repair 1 01-27-2019 06:41 PM
intermittent fuel odor Woody3 Maintenance and Repair 17 12-28-2013 10:31 PM
Intermittent Vibration at 50+mph donha1mn Maintenance and Repair 3 07-02-2013 01:36 PM
You may post new threads
You may post replies
