Common Torque secs - Taurus Car Club of America : Ford Taurus Forum
 1Likes
  • 1 Post By brn
post #1 of 2 (permalink) Old 05-03-2019, 03:32 PM Thread Starter
Year: 2015
Engine: 3.5L Ti-VCT V6
Send a message via AIM to taucor0315
Common Torque secs
I'm a stickler on correct torque for nuts & bolts. I'm going to do a flush & fill of my coolant @ 4 years & 24K mi. on my N/A 3.5 L. I know it's soon , but I like preventative maintenance , especially on an engine like this with the coolant pump buried ridiculously in the oil sump timing chain area. In particular I need a torque specs for the thermostat housing, which I'm going to remove for flushing. Some common specs for torque on these Gen 6 Taurus vehicles would help too, like spark plugs & intake manifold bolts , that many will do here to change plugs.
Just did a transaxle F & F , 3 times , to get all the fluid refreshed , I measured & it was just a hair over 5 quarts on each drain.
taucor0315 is offline
post #2 of 2 (permalink) Old 05-03-2019, 06:02 PM
brn
brn's Avatar
Year: 2013
Thermostat housing bolts 10Nm or 89lb-in
Upper intake manifold bolts - no information given
Upper intake manifold support bracket-to-engine bolt 10Nm or 89lb-in
Upper intake manifold-to-support bracket bolt 10Nm or 89lb-in
Spark plugs 15Nm or 133lb-in
taucor0315 likes this.
brn is offline
AX4N: replacing torque converter or new transmission smalltaurusbigtaurus Engine and Drivetrain 11 05-07-2019 05:02 PM
Consuming Coolant slowly, no leak visible. mrvanwinkles Maintenance and Repair 114 04-12-2019 09:24 AM
Correct torque converter part, and what else should I replace? billfrank85 Maintenance and Repair 3 11-07-2016 12:59 PM
Good torque range for 3/8" torque wrench? q0987 Maintenance and Repair 9 02-19-2014 04:20 PM
Torque mount on duratecs (gen 4)? curiosul Engine and Drivetrain 11 06-10-2013 09:00 PM
You may post new threads
You may post replies
