windshield washer fluid drain? - Taurus Car Club of America : Ford Taurus Forum
post #1 of 3 (permalink) Old 03-11-2019, 09:45 AM Thread Starter
ricer333's Avatar
So for whatever reason, the Prestone bug wash windshield washer fluid seemed to leave a residue on my car. I washed it and it seems to be caked into the finish. I'm trying to get my regular detailer to take a look but of course, as it would happen, the detailer is super busy right now.
The question I have for you all is how can I disconnect the reservoir and clean it out with some distilled water?
Is there an access from underneath the car? Is there a tube that I can simply disconnect and just rinse the reservoir out with the water?
ID:	208017   Click image for larger version
ID:	208019   Click image for larger version
ricer333 is offline
post #2 of 3 (permalink) Old 03-11-2019, 05:29 PM
brn
brn's Avatar
Year: 2013
Engine: 3.5L Ti-VCT V6
You can get to it through the front right wheel well. I forget which way you want to turn the wheel. If one way doesn't work, try the other. There's a hose that's connected to the pump. The pump is directly connected to the reservoir. You should be able to pull the hose off the pump.
brn is offline
post #3 of 3 (permalink) Old 03-11-2019, 05:37 PM
Stick a hose in it and flush the tank out like that. Then siphon for the tank until empty. That should dilute the mixture.
6F50 Transmission Fluid Drain and Refill Capacity tblomgokaboom 5th and 6th Gen Maintenance and Repair 2 11-15-2018 01:59 PM
Windshield Washer Fluid Line Replacement Alternative Lawyery Taurus and Sable General Discussion 10 08-23-2018 09:10 AM
2013 windshield washer fluid wont come out Chencho 5th and 6th Gen Maintenance and Repair 50 04-03-2018 04:26 PM
Can a broken windshield washer fluid hose cause a CEL? jimbeamalki Maintenance and Repair 8 09-10-2015 07:58 PM
WINDSHIELD WASHER FLUID WON'T COME OUT Lawyery Maintenance and Repair 10 08-27-2015 09:41 AM
