2011 Preventive maintenance question. 100000kms - Taurus Car Club of America : Ford Taurus Forum
 3Likes
  • 1 Post By sheila
  • 1 Post By DougOfWar
  • 1 Post By UKfordguy
post #1 of 4 (permalink) Old 03-05-2019, 05:37 PM Thread Starter
Year: 2011
Engine: 3.5L Cyclone V6
Hello,
I have a 2011 Taurus SEL with just over 100000kms on the odometer and I want to keep this beauty for a long, long time!
What should I do in the way of preventive maintenance? Should I have the tranny fluid changed? Coolant changed and system pressure tested? Power steering fluid changed?
Do I have to have the timing belt changed? If the timing belt goes will it destroy my engine?
Please weigh in on my questions and feel free to add in any and all advice about other aspects of preventive maintenance.
Thanks in advance,
Doug
DougOfWar is offline
post #2 of 4 (permalink) Old 03-05-2019, 09:47 PM
Doug, with the 3.5, I'd swap the coolant ea. 1-2 yrs. due to their h2o pump issue. Loosen/remove the tank cap to vent, open the petcock and drain. Refill with the recommended/specified 50/50 mix. You probably have a drain plug (11mm) for the tranny (no serviceable filter/no pan). Loosen/remove tranny dipstick cap to help vent, then remove the drain plug. Refill with 4-6 qts. Mercon LV atf. If you have a fluid ps pump and not elec., I'd empty the reservoir with a turkey baster and refill with atf. Do this occasionally until the fluid remains red. Iirc, you have a timing chain. I would only consider swapping it out during the course of an h2o pump replacement. May read the owners manual for specs, capacities, service intervals and scheduled/preventive maintenance.
Omar Ameen likes this.
post #3 of 4 (permalink) Old 03-06-2019, 01:50 PM Thread Starter
Year: 2011
Thank you very much Shelia.
I appreciate all of the information and I'm glad to hear that I have a timing chain!
I will follow all of your advice.
Cheers,
Doug
post #4 of 4 (permalink) Old 03-08-2019, 08:46 AM
UKfordguy's Avatar
Year: 2013
Engine: 3.5L EcoBoost V6
Yes coolant changes are VERY important in my opinion. I change mine twice a year. Spring and in winter.
DougOfWar likes this.
2013 Taurus SHO with Performance Package: Air Raid Cold Air Intake: Magnaflow twin pipes with performance mufflers: De-baged. SCT X4 93 Canned Tune,( 3bar map sensor, 170 thermostat, gapped plugs to be installed), smoke tint headlights
Other rides:
- 1993 Kawasaki ZX7
- 1988 Dodge Dakota 3.9 V6 5sp RWD - restored
UKfordguy is offline
Headlight Question - 2011 SEL Sudzy 5th and 6th Gen Aesthetics, Interior, Wheels and Tires 5 09-30-2018 02:46 PM
Preventive maintenance paker Maintenance and Repair 19 11-27-2017 10:09 PM
2011 taurus radio question Dans2011taurus Electronics, Security, Audio and Visual 1 05-11-2016 08:22 PM
2011 Drive/serpentine belt question? cowboyup1494 5th and 6th Gen Maintenance and Repair 3 08-06-2014 03:25 AM
2011 Sony Sound System question 2011 SHO Driver 5th and 6th Gen Electronics, Security, Audio and Visual 5 05-10-2013 09:41 PM
