Fan turning on and off - Taurus Car Club of America : Ford Taurus Forum
post #1 of 6 (permalink) Old 08-13-2018, 03:09 PM Thread Starter
Yessong's Avatar
This happens only when in the highest blower setting on my 2010 SEL/AWD. The fan will blow hard and then drop off momentarily and then start up again - it will continue this "dance" till I manually lower the speed - even by one setting - then it blows steady...thoughts on what could be causing this?
There's nothing wrong with me that several days of expensive testing can not prolong.
Yessong is offline
post #2 of 6 (permalink) Old 08-13-2018, 06:45 PM
brn
brn's Avatar
Year: 2013
Engine: 3.5L Ti-VCT V6
airflow sensor?
brn is offline
post #3 of 6 (permalink) Old 08-13-2018, 08:17 PM
Hmm. That's odd. I think it is worth looking at the digital climate control PIDs with forscan. Only other thing I can think of is checking the wiring and the plug on the fan, or it could conceivably be the high winding in the motor has a bad contact in it that opening up when it gets hot. A symptom of a broken wire in the winding is opening up when it gets hot, and then working again when it cools off.
I know that's not a lot of help.
46davis is offline
post #4 of 6 (permalink) Old 08-13-2018, 09:13 PM
Model: Mercury Sable Wagon
Could just be a problem with the blower speed motor control module. Could be a loose wire connection.
soulscourge is offline
post #5 of 6 (permalink) Old 10-10-2018, 01:25 PM Thread Starter
Yessong's Avatar
Sounds like...no matter what this could be a dealer-fix .....Blech
Yessong is offline
post #6 of 6 (permalink) Old 10-10-2018, 03:19 PM
Moderator
Agree the first step is checking for codes with Forscan.
Blind guess on the problem..... on high, blower draws too much current due to dry bushings, shorted windings, etc, the control module senses this overcurrent and reduces blower current (i.e., lowers the PWM duty cycle), thus reducing blower speed. I would assume a blower overcurrent detected would set a code that Forscan will display.
You may post new threads
You may post replies
