2013 taurus se 3.5 Transmission fluid change - Taurus Car Club of America : Ford Taurus Forum
post #1 of 12 (permalink) Old 05-30-2018, 01:39 PM Thread Starter
Year: 2013
Engine: OTHER
Bought a 2013 Taurus SE V6 3.5 with 95k miles Oct 2017 it now has 101k miles I seen manual reads trans fluid change at 100k miles, it was owned by Walgreens mostly. It felt like twice from a stop in D when ready to pull out of my driveway it felt like a small slip and bump you know the same if I would had it in neutral and put it in D. Figured either low fluid or filter getting dirty (outside temp. around 70 both times about a week apart). Later checked fluid level it was in correct after about 30 mile drive in 80 degree weather, it's been around a month and trans been working good felt nothing else wrong. I recently found out I can NOT replace filter, I intended to do drain, filter change twice. I've read that new fluid can remove old varnish build up which is going to be trapped in the filter that I can NOT change! Should I even do a drain and fill ? (read around 5 1/2 quarts) If those two slight transmission bumps I felt a several weeks ago was caused by a filter that's beginning to clog I'm I going to make things worse? I was going to use Valvoline Maxlife full synthetic atf does anybody have anything to say about that, like that's fine or noooo don't use that!!!!! I already bought it.
02TaurusGuy is offline
post #2 of 12 (permalink) Old 05-30-2018, 04:34 PM
UKfordguy's Avatar
Year: 2013
Engine: 3.5L EcoBoost V6
Hello,
Read this thread, fully. It should help you out
https://www.taurusclub.com/forum/114-...rmation-2.html
As for the fluid, I would only use what Ford recommends, which I think is Mercon LV. Ford's transmissions are picky what fluid they like!
2013 Taurus SHO with Performance Package: Air Raid Cold Air Intake: Magnaflow twin pipes with performance mufflers: De-baged. SCT X4 93 Canned Tune,( 3bar map sensor, 170 thermostat, gapped plugs to be installed), smoke tint headlights
Other rides:
- 1993 Kawasaki ZX7
- 1988 Dodge Dakota 3.9 V6 5sp RWD - restored
UKfordguy is offline
post #3 of 12 (permalink) Old 05-30-2018, 07:43 PM Thread Starter
Year: 2013
Engine: OTHER
Thanks I found a BG transmission service bout 10 miles away will call sometime and see about there service. I did forget to say the maxlife atc I bought says recommended for DEX/MERC* MERCON* LV . Also is Mercon still available? according to the short video link below at 44 secs says they don't make mercon anymore, video dated Dec.2017 talking about mercon V.
post #4 of 12 (permalink) Old 05-30-2018, 10:04 PM
Some Dexron 3/Mercon atf may still be sitting on shelves, but I've also heard production has ceased. Iirc, Mercon 5 and Dexron 6 have replaced it.
sheila is online now
post #5 of 12 (permalink) Old 05-31-2018, 09:02 PM Thread Starter
Year: 2013
Engine: OTHER
The video he was holding mercon V, but the way I took it was that ford no longer makes mercon period. So i'm assuming later versions including Ford made Mercon LV. I don't know the timeline when Ford Mercon LV came out. They may have licensed out Mercon to other ATF producers, but may have loaded dealerships with alot of Mercon, but really don't know.
post #6 of 12 (permalink) Old 06-03-2018, 04:36 PM
Smitty79's Avatar
Year: 2013
Engine: 3.5L Cyclone V6
I did a drain/fill twice withValvoline full synthetic ATF (LV). My trans didn’t like it. I recently found Motorcraft Mercon LV on RockAuto for only $4.07 a quart. I did a drain fill (measured exactly 5 quarts that came out), and my trans acts much better now. Learn from my mistake and just use Motorcraft LV!
Smitty79 is offline
post #7 of 12 (permalink) Old 06-03-2018, 06:53 PM
Even if you cant find Motorcraft Mercon V, I am sure it will be around from other suppliers for many many years to come, as there are tens of millions of Fords on the road that still use Merc V in their trannies and PS systems. Best place to get Merc V is Wally World Supertech Merc V for around $4.29 a quart. Heck Ford Type F fluid can be found everywhere and Ford hasn't built a tranny or PS system that uses Type F in 25+ years.
post #8 of 12 (permalink) Old 06-03-2018, 08:58 PM Thread Starter
Year: 2013
Engine: OTHER
What exactly do you mean smitty your transmission didn't like it?
post #9 of 12 (permalink) Old 06-15-2018, 02:05 PM
Smitty79's Avatar
Year: 2013
It shifted strange after Valvoline drain/fill. I could feel all the shifts, they weren’t smooth.
Smitty79 is offline
post #10 of 12 (permalink) Old 06-19-2018, 05:18 PM Thread Starter
Year: 2013
Engine: OTHER
Well I fiiiinally called a nearby auto repair shop that does bg transmission flushes, he said "since I don't know transmission service history prior to 95K miles (has 103K miles now) he suggests drain and fill" not a bg flush because the filter can not be changed. Since my transmission been working fine I think I will return the MaxLife fluid for a refund. If I do a drain and drop the new fluid might possible dislodge some sort of build up and clog up my filter then I would have to have it rebuilt, may as well wait and hope transmission last a long time, I'm not a hot rodder anyway. I don't take long trips either. also the place I called said they use Global multi-vehicle brand which I know 0 about.
Gen 4 Trans Pan Drop and Filter Change AX4N Sam Solutions to Common Problems and 'How To' Articles 145 08-21-2016 01:31 PM
02 taurus transmission fluid leak mwb88 Engine and Drivetrain 16 06-14-2015 07:06 PM
Ez Topic Finder qwertz9586 Introduction Forum 10 06-11-2015 05:41 PM
2000 Taurus AX4S transmission handle dipstick seal? Brcobrem Maintenance and Repair 13 05-31-2015 07:59 PM
Too Late for Trans Fluid Change at 120,000? A debate… qcy2k6 Maintenance and Repair 25 04-23-2013 03:37 PM
