2013 (Gen VI) Taurus Coolant Change Procedure - Taurus Car Club of America : Ford Taurus Forum
post #1 of 6 (permalink) Old 01-14-2017, 02:34 PM Thread Starter
ricer333's Avatar
Does anyone know of a good procedure to change the Orange coolant in the GenVI bulls?
My GenIV, we simply opened the clamp on the passenger side T-junction (lowest point) and drained it from there. I haven't been under the new bull enough to know if there is a similar T-junction/low point like the GenIV's.
I'm sitting at just over 61k. I think I just read on another post that Ford doesn't recommend changing the coolant till 100K??? That seems a bit extreme, as well as the transmission fluid at 150K.
Any help is greatly appreciated!
ricer333 is offline
post #2 of 6 (permalink) Old 01-14-2017, 06:51 PM
Radiator petcock? Tranny drain plug? If so, you're looking at fluids and a 1/2 hr.
post #3 of 6 (permalink) Old 01-15-2017, 09:19 AM
Gen 5/6 Forum Moderator
Year: 2017
Model: OTHER
Engine: OTHER
Honestly, in my Bull I was planning to change it at 60k, max, for the trans fluid. No way in HELL that fluid should go that long. No comment as to coolant, although as a matter of practice we like to flush that as well before too long.
The trans in our 6F35 Escape was starting to have issues at 35 (it was also several years old, which didn't help the wear any). I had it flushed at Quick Lane, all the problems vanished. I doubt the 6F50/55 twins have any better fluid dynamics.
thefranchise713
thefranchise713 is offline
post #4 of 6 (permalink) Old 01-20-2017, 08:20 AM Thread Starter
ricer333's Avatar
sheila,
Sorry for the confusion. I was primarily looking for recommendations or a procedure to change the engine coolant. I was only mentioning the transmission oil/fluid at ~150k to draw attention to what Ford recommends the transmission oil change procedure to be done at.
By the way, are there transmission oil drain plugs on these newer cars? I know the filters are not replaceable as they are tucked way up in side the transmission.
Edit: grammar purposes
ricer333 is offline
post #5 of 6 (permalink) Old 01-20-2017, 10:13 AM
^ Dunno. On my '12/'13 Impalas, there's a radiator petcock and an atf drain plug. Literally takes mins. to change both. Like your Ford, there's no atf filter to contend with. It's also inaccessible w/o removing and cracking the tranny case open.
post #6 of 6 (permalink) Old 01-20-2017, 01:29 PM
Year: 2010
Engine: 3.5L Cyclone V6
There is a radiator petcock on the driver side of the radiator. You have to remove the front plastic lip (undertray?) under the bumper cover to get at it.
twiggy144 is offline
Retrofit DONE! Active Lane Keeping Assist in a 2013 Ford Taurus apial 5th and 6th Gen Electronics, Security, Audio and Visual 11 10-29-2016 02:55 PM
2013 Taurus limited Alternator Removal quadcells 5th and 6th Gen Maintenance and Repair 14 09-16-2016 09:23 AM
Some mods on a 2013 Taurus SEL? James417 5th and 6th Gen Engine and Drivetrain 15 03-24-2016 12:23 AM
04 Taurus coolant maintanance question Jp1969 Maintenance and Repair 8 09-01-2015 11:27 AM
2013 SHO Fluid Change polskifacet 5th and 6th Gen Maintenance and Repair 6 08-30-2015 11:35 AM
You may post new threads
You may post replies
