2008 Taurus SEL Transmission Shudder Fixed! - Page 2 - Taurus Car Club of America : Ford Taurus Forum
 4Likes
post #11 of 13 (permalink) Old 08-12-2017, 04:50 PM
Year: 2009
Model: Ford Taurus X
Engine: 3.5L Cyclone V6
Reporting back. Problem is gone after replaced all spark plugs. The old plug is motorcraft platinum and the gap is obviously much wider.
Replaced with NGK Iridium IX plugs and happy now. It runs like new again, maybe will run for 10 more years. First time see an engine sensitive to spark plugs.
2009 Taurus X
2005 Freestyle
goTouch is offline
post #12 of 13 (permalink) Old 10-30-2017, 09:35 AM
billzie's Avatar
Year: 2008
First off, I wish the OP would check back in to this thread, I know it's old but would like more info please. Questions for you first then my input follows...
Do you have any other pics? ie, you mention a chain and pump with 3 bolts to remove to get to the filter, but I see neither of those landmarks in your pics.
If debris caused the TC to fail, the debris came from other failing parts in the trans, changing the filter must have only been a temporary "fix" IMO. Did your trans eventually fail and need a rebuild?
What sealant did you use when reassembling the case halves (looks like Ford uses a white/grey color)?
Did you replace any of the seals while you were at it?
I'm in the process of swapping a donor trans into what should be my DD 08 T-X AWD Limited (yeah, Limited road time lol). I pored over YT, here, and anywhere else I could get info and there wasn't much, and unfortunately I didn't get a set of dealer manuals yet which I usually do with my vehicles.
To remove the trans in this platform you MUST remove the K member cradle, whether you drop the enter engine/trans with it or suspend eng and only drop trans, it MUST be removed. On the donor 08 Sable AWD I suspended the eng with the eng/trans susp tool (I wish I had 2 lol), but on the T-X I'm dropping the eng/trans/K member together, then separating the eng/trans, it took me forever getting it donor out (the AWD PTU complicates things), I also want to do the water pump as preventive maintainace (145,000 mi but new to me).
I had no problem removing ball joints or tie rod ends, like most vehicles, before and after removing the nuts spray with penetrating oil, find the meaty side of the steering knuckle where that part mounts, and whack a few times with a hammer and the usually pop right out.
I found it easier to disconnect the lines to the rack and leave it on the K member rather than removing and suspending it.
That's as far as I got to this point, if getting to that filter is as easy as the OP makes it sound I am adding it to my RA order and will change it out.
Hopefully the OP and those with this experience will reply.
And to astute viewer, yes I'm also trying to find a donor eng for my 06 Trailblazer and Yes I also have old faithful a 02 Sable Wgn LS Premium (only vehicle I own out of 6 currently running).
Thanks, Bill.
ID:	197786   Click image for larger version
ID:	197794   Click image for larger version
ID:	197801   Click image for larger version
billzie is offline
post #13 of 13 (permalink) Old 10-30-2017, 01:16 PM
Play Nice or Don't Play
jag1959's Avatar
Engine: 3.4L Yamaha V8
The OP hasn't been on in a year and a half. Have you tried sending a PM?
It's SHO time!
jag1959 is offline
1992 taurus 3.0 needs a transmission 98indy500 Engine and Drivetrain 1 09-01-2014 04:58 PM
02 Taurus - Wrong Transmission Question Sgat8516 Engine and Drivetrain 9 05-24-2014 11:24 PM
Does The 2008 Ford Taurus Have a Camshaft Synchronizer? swiv101 5th and 6th Gen Maintenance and Repair 2 12-09-2013 05:10 AM
Transmission issue p0732 p0733 1988 taurus wagon 98bullwagon Engine and Drivetrain 2 11-30-2013 08:45 PM
wheels from a 2010 taurus fit a 2008 Taurus? eckell3 5th and 6th Gen Aesthetics, Interior, Wheels and Tires 1 10-28-2013 09:28 PM
You may post new threads
You may post replies
