SHO decarb - Taurus Car Club of America : Ford Taurus Forum
post #1 of 4 (permalink) Old 05-03-2014, 08:01 PM Thread Starter
SHO decarb
Since our engines are DI there is possibility of carbon buildup. I will share my experience of decarbing with you guys.
Materials:
http://www.polishedconcretesolutions...ssure-sprayer/
http://www.berrymanproducts.com/prod...ector-cleaner/
First disconnect the map sensor which is on the intake pipe and then disconnect the intake pipe from the throttle body. I usually use two cans of chemtool in the sprayer. Have a helper start the car and his task will be to keep the car from stalling out. The engine should start without a problem. Spray the chemtool directly into the throttle body (don't touch the butterfly valve, you can damage the servo). I spread out the spray time into 4 parts so the cats could get a break to cool down. Make sure that the space you are doing this in is well ventilated. Turn off the car and reconnect the sensor and intake pipe.
Optionally:
Disconnect the PCV hose on the intake piping closest to the air filter and spray chemtool into the pipe nipple. By doing this you can clean the oil out of the piping and intercooler.
Disclaimer:
I am a gear head and a servere car enthusiast with years of experience including a fully built 400 hp Scion TC. I can not be responsible for any damage that may incur to your vehicle if you do something wrong. If you use common sense you should be fine.
polskifacet is offline
post #2 of 4 (permalink) Old 05-03-2014, 09:16 PM
How about an RX or Elite catch can?
sheila is online now
post #3 of 4 (permalink) Old 05-03-2014, 09:29 PM Thread Starter
You can use a catch can but that doesn't guarantee no buildup on the valves. We also have a oil separator built into the engine already.
post #4 of 4 (permalink) Old 05-03-2014, 09:51 PM
^+1. I've got the single valve RX catch can and 1LE oil separator on my DI engs. from Tracy at RevXtreme.
