08 Taurus hvac issue - Taurus Car Club of America : Ford Taurus Forum
post #1 of 5 (permalink) Old 12-09-2013, 09:24 PM Thread Starter
ceejpea's Avatar
I have a 2008 ford Taurus sel that is having hvac issues. I purchased the car almost 2 years ago and every so often I would get a loud clicking noise (drivers side dash) when I started the car and the a/c or heat was on. Then after about 10 seconds it would stop. Well now it clicks about 10 seconds every time I start the car but sounds really low and the air only blows out of the vents in the dash. The heat and a/c work great but I can not get it to change from the vents to the floor or the defrost settings. I have a dual climate control EATC unit and have done the self test and get a code of 10 03. I have not been able to find what this code means anywhere. I think it may be the mode door actuator has gone bad. If this is the case what do I have to do to replace it and what can I do to confirm this is the problem. Thanx
ceejpea is offline
post #2 of 5 (permalink) Old 12-10-2013, 10:15 PM
Clicking sure sounds like a bda issue. May pm member Taurus Bear.
post #3 of 5 (permalink) Old 12-12-2013, 07:44 PM Thread Starter
ceejpea's Avatar
I pmed him Thanx
ceejpea is offline
post #4 of 5 (permalink) Old 05-01-2019, 02:59 PM
Could you briefly explain how you did the self test and how long it took the test to complete? I was able to get a test started today, the screen was all lit up with 88.8 showing which I am told means the test is running, but I let it run for over 30 minutes and never completed.
Richman is offline
post #5 of 5 (permalink) Old 05-01-2019, 03:12 PM
^ Iirc, 888= everything checks out?
1992 Ford Taurus Transmission Issue Allen90 Maintenance and Repair 4 04-25-2017 06:53 PM
08 Taurus sel HVAC issue ceejpea Maintenance and Repair 0 12-09-2013 09:02 PM
Weird Transmission issue or just Taurus quirkiness???? pimpninja Maintenance and Repair 3 09-09-2013 05:27 PM
Looking at a 92 Taurus w/56k w/overheating issue dartheyeball Engine and Drivetrain 19 08-04-2013 09:56 AM
2000 Taurus Not typical Door Ajar Issue mrpooky Maintenance and Repair 8 04-06-2013 05:51 PM
