2005 Ford Taurus HELP P0174 and P0300 - Taurus Car Club of America : Ford Taurus Forum
post #1 of 4 (permalink) Old 01-06-2019, 04:57 PM Thread Starter
I own a 2005 Ford Taurus with just under 70,000 miles on the 3.0 OHV V6 and Have been trying to diagnose two codes i am getting for 6 months now and will take all the help i can get . The two codes are P0174 (System too lean Bank 2) and P0300 Random/Multiple Cylinder misfire Detected.
So far i have done the following
1. Replaced all of the spark plugs and tested the wires.
2. Replaced the coil pack
3. Replaced all of the O2 sensors
4. Replaced the fuel filter
5. Filled up tank full and added a water remover to purge any water in the fuel lines
The car does start and drive and im getting about 20 to 25 MPG
it is usually run when the outside temperature is under 40 F
notice a very very rough idle when starting up
When at freeway speeds i do not notice much variance in the RPM,however i can feel a slight misfire or irregularity in the engine when i am accelerating from about 50-60 mph
the RPM at idle when the engine is warmed up is around 500-600
Any help what so ever is much much apprecated
Also this is my first post , let me know if there is any additional info that i can provide .
Thanks
Blaine Levine is offline
post #2 of 4 (permalink) Old 01-06-2019, 05:11 PM
Welcome Blaine! You most likely have an undetected vacuum leak(s). Short/long term fuel trim readings would be helpful in diagnosing if you have access to a scan tool.
post #3 of 4 (permalink) Old 01-06-2019, 05:44 PM
Welcome! Driving with a misfire any extended period have been know to destroy catalytic convertors.
post #4 of 4 (permalink) Old 01-06-2019, 10:59 PM
TollKeeper's Avatar
Model: Mercury Montego
I agree with @Automender12345 , I would also like to suggest that you post your problem in the forum dedicated to your car. Althou the intro forums do get some traffic, its not nearly as much as the main forums.
Welcome to TCCA.
Brian - Carpe Diem
2005 Mercury Montego 52k
2004 GMC Envoy XUV 182k
TollKeeper is offline
Fuel problems with 2004 Ford Taurus. richie33 Maintenance and Repair 3 06-06-2017 11:23 PM
p0171, p0174 & p0300 irritation kangbroke Maintenance and Repair 43 12-22-2016 01:25 AM
You may post new threads
You may post replies
