Exocet's 2007 Volvo V70 - Page 8 - Taurus Car Club of America : Ford Taurus Forum
 27Likes
post #71 of 80 (permalink) Old 08-10-2018, 07:28 PM Thread Starter
A power off reset seems to have fixed things. Runs fine with no codes. Nice to be operational again. But, quirky electrical problems are the one thing that I fear most with this car.
2003 Mazda Protege5, 2.0L (Daughter #1)
2008 Nissan Titan SE, Crew Cab/Long Bed, 5.6L (Mine)
2007 Volvo V70 2.5T, turbo 2.5L (Mine)
2010 Mazda 6 Grand Touring, 2.5L (Daughter #2)
2012 Toyota Camry LE, 2.5L (Wife)
Exocet is offline
post #72 of 80 (permalink) Old 08-22-2018, 06:42 PM Thread Starter
Swapped the engine system relay and the starter relay. Had 4 no starts in a week (no starter engagement). Replaced starter relay and all has been fine. So, looks like the engine system relay was going bad.
Exocet is offline
post #73 of 80 (permalink) Old 08-22-2018, 06:43 PM Thread Starter
Hit a 150k miles today.
Exocet is offline
post #74 of 80 (permalink) Old 09-23-2018, 10:19 AM Thread Starter
Pulled the bumper cover to replace the headlights with a pair of almost new JY units. No more cataracts!
While I was in there, I replaced the turbo to OTE (over the engine) pipe hose and the OTE pipe to intercooler hose. Of course, the lower clamp on the turbo hose is almost inaccessible. So, a 30 min job takes an hour after I drop my 7mm wrench into the abyss, forcing me to drop the lower engine shield. But, no more oily messes.
Also installed my painted coil and timing covers. Added a intake/injector cover from an R model. Finally, added a larger OTE pipe from a T5 model.
Sent from my SM-G950U using Tapatalk
chartmaker and sousa632 like this.
Exocet is offline
post #75 of 80 (permalink) Old 09-23-2018, 03:31 PM
I'll Be Watching You!
sousa632's Avatar
Year: 2007
Model: OTHER
Engine: OTHER
Looks good!
John
sousa632 is offline
post #76 of 80 (permalink) Old 09-29-2018, 12:21 PM Thread Starter
Fabricated a wire mesh grill. Newer JY S60 headlights, which have black accents instead of the V70's gray. Polished the fog light lenses and installed amber bulbs. Painted the lower bumper opening crossbar black.
Exocet is offline
post #77 of 80 (permalink) Old 10-24-2018, 05:48 PM Thread Starter
How most Volvo owners feel when they find out their PCV system is clogged. Yes, a rubber glove is the unofficial way to test it.
Exocet is offline
post #78 of 80 (permalink) Old 10-27-2018, 10:43 PM Thread Starter
Over the past 2 weekends I've replaced the following: alternator, serpentine belt and tensioner, radiator hoses, heater core, HVAC blower, and antifreeze.
The only "repair" items left are the LCAs and ball joints.
Exocet is offline
post #79 of 80 (permalink) Old 11-04-2018, 05:28 PM Thread Starter
Replaced the lower control arms Saturday. Come out easy, but much more difficult to install. Need to be careful not to over extend the inner CV joint. Used a cargo strap to ratchet down the arm far enough to get the ball joint in. No luck on the ball joints. My improvised slide hammer didn't cut it. Need new dust seals on the hubs.
Exocet is offline
post #80 of 80 (permalink) Old 05-19-2019, 08:06 PM Thread Starter
The V70 made it through the winter without any issues. Just turned 160k miles. Some spring cleaning and updates prior to the Import Nationals. Repainted the original wheels in a hypersilver over black. New Nokian ZLine A/S tires on all 4 corners. Upgraded to the premium audio (speakers, 300W amp, and door panels) and added dynamat to the doors. Cut out the resonator and straight piped it. Added a set of Hella Sharptone horns. Hit 31 MPG on the run back from Carlisle today. Burning a qt of oil every 3500 miles.
Still working on the projector headlight retrofit.
Exocet is offline
MOVE 2003 SES adjustable brakes TO 2007 Se aleo101 Suspension, Handling and Brakes 4 08-30-2016 07:50 AM
2007 SEL AJAR, now Alarm Issue bluehorn Maintenance and Repair 8 03-30-2014 10:30 PM
Got my mind set on this one 2007 Charger Police godfather Odds and Ends 22 01-31-2014 08:33 PM
2002 Taurus with 2007 Taurus parts lworley18 Engine and Drivetrain 34 09-20-2013 06:55 PM
2007 Fuel Pressure Readings is my pump good? qcy2k6 Maintenance and Repair 9 04-20-2013 05:38 PM
