in my daughter memory
but hey it was not ready
now it just need some water sanding and a good buff and a wax coat before winter lol
so here go
this is a 94 taurus gl no option
it now has 2007 electric seat sho 95 cluster and blue led plus chromed bezel plus blue led under dash light and white led for the 2 door marker plus 5 pinkinsh neon one for the logo and 2 in front and 2 rear seated
it a 3 time engine was rebuilted the last one is from a mustang block
1 installed 1 used tranny and it lasted not long and the 2 one was rebuilted with shift kit bigger torque convertor and secondary cooler
brake where updated from a drum rear setting to vented sho setting
front brake where updated to 2000 gt dual piston caliper with SteeL Braided brake line on all 4 corner
with cross slided rotor and ceramic pad and new master since 1 month
suspention is eibach pro kit with new top plate and monroe strut ( will have koni insert soon)
front 24 and rear 26 mm sway bar from a sho
all the frame bushing strut bar bushing sway bar bushing are all moog blue plastic
sub frame connector are aluminum cup and engine is chained to the frame even do it has 2 new engine mount and 1 tranny mount
link kit front and rear moog plus ball joint moog sho version
disco ball with hid digital 55W 6000K
4 foog light when i need more
new rack and pinion and new rad from ford
4 yokohama avid trz 16 on windstar sel mag
4 toyo go2 winter tire on rim
1 remote starter and alarm and cutoff ignition switch
1 jcv kbt1 radio with 4 gig usb key and blutooth in phone car service
1200 amp battery with huge post gold plated
1 wire code 2 for the power on the 3 amp yeah i know it over kill
3amp in trunk
1 sony 444 for the front
1 phoenix gold old amp now doing the rear 6X9
1 alpine 350 mono bloc that run 2 12 " sub
2 12 " coil over sub from pionner
and there you my voting picture
[attachmentid=26477]
hope you enjoy this me it took for ever to complete the car job
so here go
3amp in trunk
