IPB
Welcome Guest ( Log In | Register )
Site Name : Maximum Performance Products
Submitted By : J Rod
Submitted On: Mar 14 2009, 05:20 AM
Clicks Counts: 6431
Description:
Authorized AMSOIL Dealer!
Welcome to the TCCA, Please Register or Login to Remove this Message!
Hello and welcome to Taurus Car Club of America, the #1 resource on the internet for the Ford Taurus and Mercury Sable! If you are looking for information on the 2010 Taurus and Taurus SHO, you've come to the right place. We also specialize in all other years clear back to 1986! Feel free to browse around or jump right in to the discussions! We're sure you'll find what you need for your Taurus or Sable!
Like most online communities you must register and login to post and use other forum features in our community, but don't worry this is a simple and free process that requires minimal information. Remember to check your in box for the email validation after you register! Register Now
Login User Name
Login Password
Forgot Password
> Rules for this forum
This forum is for Solutions to Common Problems and 'How To' Articles written by our members. Topics can only be moved here by the Mods. You may, however, reply to any of the topics in this section. If you have written a topic or you see a topic that should be in this section, use that topic's report button to inform the staff. If the topic meets the criteria for this section, it will be moved. Topics may also be edited by the staff for any reason if needed.
3 Pages V   1 2 3 >
Reply to this topicStart new topic
How I Repaired An Ax4n Tranny, Very long with some pictures
powertoolman
post Jan 8 2005, 05:47 AM
Post #1
Group: Members
Car: Ford Taurus
Year: 1996
New Edit:
I wrote this posting over 4 years ago. I am not a tranny expert and I do not even own the car anymore. I am glad this posting has been helpful to so many people, but I don't recall anything of the task I did back when I wrote this. It is nice getting emails from people thanking me for the information, but I can't really help you out with technical questions.
Instead of just taking information from this forum, I thought I would give some back, by providing an update to a transmission question I posed a couple of months ago. Since I'm a technical writer/engineer, I'll even give a quick rundown on the repair I completed (I saved myself over $2,000 with about 2 days of semi-skilled labor).
Symptoms: My 96 AX4N transmission would hesitate engaging at a stop sign and eventually completely failed with no forward or reverse gears. There was absolutely no engagement, so the clutch pack was not suspected as a problem.
Diagnosis: Before I did anything else, I checked to see if the pump was working (based on telephone advise from a helpful tranny shop). With the car cold and NOT running, I checked the tranny fluid and made note of how high on the dipstick it was (it should be VERY high). I wiped the dipstick off, but did not replace it yet. I then started the car and inserted the dipstick back in within 10 seconds, and rechecked the level. Since the level dropped, I thought the pump was working. Actually, I think if I had re-checked the level when the engine was warm I would have found the level to still be high (I later discovered the pump had failed).
I next towed the car to an AAMCO shop that read the computer tranny codes at no charge. He came up with three codes indicating incorrect gear ratios and a fourth code (the root-cause code) indicating that the torque converter control valve was stuck.
The technician (very helpful) suggested that the retaining clip on the control valve was broken, and this caused the valve to get stuck. This is apparently a common problem because the valve slams into the retaining clip fairly hard. He then took me down to the repair area and showed me an AX4N valve body, the location of the control valve, and what the retaining clip looked like.
Research: Before I began, I went to the library and accessed the "AllData" web site. This is a mechanic's resource site with a very expensive subscription, but my library provides it for free. I located the procedure for removing the pump and valve body from a Taurus. The procedure was not very clear, but it did show a drawing of what bolts need to be removed. (I have a better picture shown below though).
I also checked out a copy of the Haynes manual (not Chilton) for the Taurus. It doesn't describe how to remove the valve body, but it did show me how to remove the motor mount and sub-frame. However, it failed to tell me I needed to remove the main cross member (neither did AllData).
Postscript After posting this and re-reading it, I realized that the rest of this discussion seems one-dimensional. What you should note is that most of the AX4N tranny problems are related to the valve body. The same procedure and discussion is useful for ANY valve body problem even though mine was the pump. Getting the valve body out of the tranny is $1800 worth of the total repair!
Final Cause: It wasn't until after I got the car apart that I discovered the real cause of my problem. All of the symptoms pointed to the control valve. However, I discovered that the pump shaft had sheered and the pump was fouled up with metal pieces. There was enough friction between the two halves of the broken shaft to make the pump turn slightly, and this is why I didn't detect it earlier.
Inside the pump are two guide rings. These broke and the metal pieces were trapped inside the pump body. The pump would still function properly under high RPM even without this rings. However, at some point the metal pieces jammed into the vanes and seized the pump. This caused the pump shaft to sheer off. The inset photo is an Internet picture of what the pump is supposed to look like.
<!--aimg--><!--Resize_Images_Hint_Text--><!--/aimg-->
Repair Options: For $200 I could get new pump parts, but there is a risk that metal got into the solenoids (which are electromagnets). Or for about the same price, I could get a complete valve body and pump at a junkyard. I chose the junkyard. (The junkyard would have provided a completely rebuilt valve body for $350.)
Tools:
When I took on this project, I assumed that with the $2000 savings I could buy some additional tools. I bought a bunch of tools, but the ones listed below are what I really needed.
Metric socket set with a wide variety of extensions and universal joints.
Air ratchet is helpful but not required.
Impact wrench with metric sockets.
Jack stands are mandatory.
At least one floor jack.
Disassembly:
To help me reassemble the car, I took a bunch of pictures.
1. Clean the engine compartment to prevent dirt from falling into the open tranny.
2. Remove the battery, battery box, and battery support bracket.
3. Remove the air intake box and sensors.
4. Disconnect the main wiring harness that is sitting over the tranny control cover. This is a large rectangular connector with a bolt running down the center to hold it together--remove the bolt. You also need to remove this connector from its mounting bracket. I think there is a retaining tab, and then it just slides off. This took a little while to figure out.
5. Do what ever else is necessary to get the rest of the wiring out of your way. Go have a beer, relax, and try it again. You need to have the whole area directly above the tranny side cover clear in order to remove the cover. It will be a tight fit as it is.
I noticed from the new batch of photographs that there was another harness connector I removed. (I suspect two of them actually). This connector is located above the shift link shown in one of the photos below. It may have been the one leading to the tranny solenoids.
6. Jack the car up and remove the driver's side wheel.
7. Turn the steering wheel to give you better access to the wheel well.
8. Place at least one jackstand under the car behind the wheel. Important: Make sure the jackstand is under the unibody frame and NOT under the main cross member supporting the engine. I had to place an additional jackstand under the front of the car to keep the right-rear wheel from lifting.
8.5 (Missing Step) Remove the inner plastic splash guard from the wheel well.
9. With the car's frame supported by jackstands, relocate the floor jack to support the driver's side of the engine (support but don't lift).
10. Remove the isolator (1-nut and 2-bolts) and motor sub-frame (3-bolts and 2-nuts I think). (You won't be able to remove the parts yet.)
11. Raise the engine slightly (mainly to know it is supported).
12. Remove (at least partially) the two bolts that secure the main cross member to the unibody frame. (The main cross member is what the isolator is sitting on. You'll know it when you see it--it is the main support for the whole front of the car.) This is necessary because you don't have enough clearance between the cross member and the unibody frame to remove the engine mount. I found that lowering the cross member an inch or so was all I needed (I did not remove the bolts). I also found out that my cheap impact wrench was not strong enough to loosen these bolts. A friend brought his Ingersol-Rand impact wrench over and made quick work of the bolts.
13. Raise the engine until the engine sub-frame touches the wheel well (as far as it can move) and remove the isolator by moving it toward the rear of the car (big hammer helps).
14. Using some finesse, remove the engine sub-frame from the engine first, and then the transmission. Raise and lower the engine a couple inches as needed to give you the clearance. Be careful. The reason why this is tough is because there is a stud on both the engine and transmission that you need to clear before you can move the frame. Don't bend these studs.
15. Drain the Transmission fluid. I removed the main pan and drained the fluid before I removed the side pan. I thought I had done this with almost no mess, but the next morning I discovered that the transmission had hemorrhaged more fluid over night. I later realized that the cooling lines had drained over night.
16. Remove the nearly two dozen screws that secure the side pan to the transmission. Some screws are accessible from the engine compartment and some are accessible from the wheel well.
17. If the gasket is a thick, ribbed rubber then it is reusable, so be careful not to damage it. If it is cork, then throw it away.
18. Carefully remove the side pan through the top of the engine compartment. It will be a tight fit, but it will fit. Remember, the front face of the valve body has solenoids on it and you don't want to damage these (see picture below).
19. Disconnect the wire connectors at the 5 solenoids (3-right and 2-left) and the temperature sensor at the very bottom. (My wiring harness was stiff enough that replacing it later was a no-brainer--all of the wires lead straight to their respective solenoid.)
20. Disconnect the linkage arm at the top-rear of the valve body (near the wiring harness you just removed).
21. If I remember correctly, there were 25 screws holding the valve body to the transmission. The 4 screws across the bottom are shorter than the others. The 5 of 7 screws through the pump cover are longer than the others. If you remove a screw that seems too short, stop and put it back in before removing any others (especially on the pump cover, you don't want the internal parts to fall out).
22. With the screws removed, the valve body should pop off the transmission with just a little effort. Pull it straight back toward the wheel well. Note that the pump shaft is fit tightly, so cocking the valve body may cause it to bind. The pump shaft MUST stay with the transmission or you can't remove the valve body (it extends into the torque converter by about 8 inches). Because my pump shaft scored the sleeve in the valve body, I had a hard time pulling the shaft out of the valve body, and thought there might be some type of retainer--there isn't. It is a slip-fit spline, so everything should come apart easily.
23. With the valve body removed, if you need to replace any of the 3 right-hand solenoids, press in on the retainer, rotate them slightly, and lift them straight out.
24. The two analog solenoids are held in with brackets. Remove the screws and lift the solenoid out.
25. If you need to replace any of the valves, I would recommend bringing the valve body to a tranny shop for a rebuild. This should still be pretty cheap.
26. When you replace the valve body and cover, I recommend counting the number of screws as you torque them down so you don't miss any.
27. After refilling the transmission with fluid, recheck it after running the engine for a short time, and again after it has warmed up. For me, I forgot about the fluid that drained out of the tranny cooler, and ended up running low in the first minute or so.
If you like this type of information, you might be interested in some of the articles I've written. The most popular is "Electricity in the Woodshop" (a comprehensive discussion about electricity and wiring). Click on the link below to go to my main web site.
Rick Christopherson
Waterfront Woods
This post has been edited by powertoolman: Apr 13 2009, 08:11 PM
Go to the top of the pagePM
+Quote Post
topgunovrtx
post Jan 8 2005, 11:37 AM
Post #2
Group: Members
Car: Ford Taurus
Year: 2000
Engine: 3.0 DOHC (Duratec)
You did an incredible job of documenting your work and giving back to the Club. Very professional. Thanks.
+Quote Post
95SE
post Jan 8 2005, 11:55 AM
Post #3
Group Icon
Group: Premium Supporter
All that work and you didn't install a shift kit? LOL!
On behalf of the Tcca I would like to commend you on your efforts! I wish more people would take the time to learn these things!
I will be doing a couple transaxle overhauls/upgrades in the next year here. I have never rebuilt an AX series transaxle, but have done a few rwd ford transmissions. I bought the ATSG book and video. The video was good, but geared for training experienced transmission guys on how to work on the ax4s. Had I not previously rebuilt some Ford AOD's and 4R70W's I would not have understood their terminology. Hand on experience is the best way to learn!
Again, great job! someone should archive this or put it in an article.
Jeramie
+Quote Post
SHOZ123
post Jan 8 2005, 12:04 PM
Post #4
SCT tuner
Group Icon
Group: Technical Advisor
Car: Ford Taurus
Year: 1997
Engine: 3.4 Yamaha V8
Chapter Forum Moderator!
Really good job. I think we should hire you for the FAQ page documentation.
I had a TC solenoid replaced last spring. Cost $450 with about $80 in parts. If I'd had this I would have done it my self.
+Quote Post
Guest_Bob Gervais_*
post Jan 8 2005, 03:30 PM
Post #5
Guests
EXCELLENT documentation! We'll be adding this to the FAQ, if you don't mind.
On behalf of the entire club, I think I can safely say thank you very much!
+Quote Post
godspunk32
post Jan 8 2005, 04:10 PM
Post #6
Taking over the world, one pint at a time.
Group Icon
Group: Gold Supporter
Wow!!! That was freaking awesome!
JR
+Quote Post
mwt
post Jan 8 2005, 04:33 PM
Post #7
The voices in my head don't like you
Group Icon
Group: Select Supporter
Car: Ford Taurus
Year: 2000
Mike
+Quote Post
TrueBlue
post Jan 10 2005, 10:12 AM
Post #8
2-Time COTM Winner, TCCA Graphics Creator, Co-Originator of ROTB
Group Icon
Group: Platinum Supporter
Event Award!  Visit my profile for a list of TCCA Events I have attended!
Damn man, feel free to strip us of info anytime you want, so long as this is how we're repaid. icon_mrgreen.gif Well written and shot.
+Quote Post
powertoolman
post Jan 10 2005, 11:09 AM
Post #9
Group: Members
Car: Ford Taurus
Year: 1996
Thanks for the positive comments. When I get to the office tommorrow I will look to see if I have the other pictures I took. If I find them, I will edit the original posting to include them.
Off the top of my head I know I took a picture showing the engine mount and possibly another one showing the wiring harness. Check back in a day or so.
+Quote Post
Guest_SableSal_*
post Jan 10 2005, 03:55 PM
Post #10
Guests
Powertoolman, Great Write up! Good info. I know that the rest of us can benifit from this. Thank you!
Sal
+Quote Post
powertoolman
post Jan 11 2005, 12:36 PM
Post #11
Group: Members
Car: Ford Taurus
Year: 1996
I found the missing pictures and added them. I also corrected a trivial mistake and an ommission.
+Quote Post
Non SHO'er
post Jan 11 2005, 06:16 PM
Post #12
Group: Members
Would these instructions apply to the Gen II Taurus as well?
So you can ramove the pump and valvebody without removing the whole transmission from the vehicle?
+Quote Post
Damon
post Jan 11 2005, 06:22 PM
Post #13
Lurkin'
Group Icon
Car: Ford Taurus
Year: 2003
Nice Writeup!
I just want a library like yours (Provides all-data for free!)
-Damon
+Quote Post
powertoolman
post Jan 11 2005, 07:52 PM
Post #14
Group: Members
Car: Ford Taurus
Year: 1996
QUOTE (Non SHO'er @ Jan 11 2005, 06:16 PM)
I'm not a Taurus guru, so I don't even know what a GenII is. However, the procedure is generic enough that I believe it will work on all models and years, including the AX4S.
The only thing that I do know will change is the bolt pattern on the valve body. For example, the AX4S has 3 bolts across the bottom and the AX4N has 4 bolts.
I show the 5 bolts that are not removed for the AX4N. On the AX4S, you will simply need to look for the short bolts (in similar locations to mine). There is nothing wrong with removing too many bolts as long as you keep at least one bolt in the pump cover to keep the vanes and rings from falling out.
+Quote Post
Guest_jason8225_*
post Jan 11 2005, 11:31 PM
Post #15
Guests
+Quote Post
95SE
post Jan 11 2005, 11:42 PM
Post #16
Group Icon
So could you theoretically remove the valve body (say to install a shift kit), with the transaxle in the car?
+Quote Post
sabledale
post Jan 12 2005, 01:51 AM
Post #17
sabledale
Group: Members
Car: Ford Taurus
Year: 2004
very nice documentation.
+Quote Post
Taurusse1995
post Jan 12 2005, 02:21 AM
Post #18
Group Icon
Car: Ford Taurus
Year: 1995
Engine: 3.0 OHV (Vulcan)
Very Nice as well I had the same issue If i had this info 2 Months ago this would have been good....And I would Have saved X amount of dollars...Very Nice documentation....Wow reading all that put me In Jumbles...GOOD JOB! thumb[1].gif
+Quote Post
larrylange
post Jan 12 2005, 04:03 AM
Post #19
Group: Members
Car: Ford Taurus
Year: 1995
Engine: 3.8 OHV (Essex)
These instructions apply to Gen I and II as well.
Powertoolman did a good job indeed. It is the exact way we are working overhere in Germany.
Larry
+Quote Post
FORMER FORD GUY
post Feb 8 2007, 02:53 PM
Post #20
Group: Members
Car: Ford Taurus
Year: 1997
I have a 97 Taurus GL with the AX4N and started to do some searching on the internet when my tranny started to act up.
The symptoms were:
- slow to engage into drive when taken out of park or neutral
- "service engine soon" light came on and, though I forgot what the code # was, the reason was because the torque convertor was not locking up at highway speeds.
- eventual "surging" when at a complete stop. this was from the tranny doing what felt like jumping back and forth from drive to neutral ,though the gear selector was not moving nor was it stuck between D and N.
My searches turned up your posting and, suspecting (and hoping) the problem was due to a bad pump, I decided to tackle the repair in my garage.
It turns out my suspicion was correct, the pump input shaft bearing had come apart and the pieces of the bearing were keeping the pump from supplying enough fluid to stay in gear at low engine speeds and lock up the TC at highway speed.
I want to say a big THANK YOU! for your posting. I don't know if I would have attempted this repair if I hadn't seen your article first.
The instructions were very good, clearly enough to do the job if you have some basic mechanic skills and tools.
I do have one tip for anybody doing this repair: you don't have to remove the metal battery support bracket completely. Mine was stuck to the body with some type of sealant and aven after removing the retaining bolts, I would have had a hard time removing the bracket. As long as you remove the plastic tray and the battery, you have plenty of clearance.
Also, because I couldn't seem to get enough clearance to do so, I never removed the engine sub-frame completely form the car. I just removed all of the bolts and nuts and moved the sub-frame away from the engine enough to remove the pan.
The entire repair took about one 10-hour day and cost me about $230 for a new pump, housing, and shaft. The tranny place that got the new parts for me said they would have charged about $700 for th total repair. The savings was well worth the effort!
THANK YOU POWERTOOLMAN!
+Quote Post
s2knott
post Feb 9 2007, 11:53 PM
Post #21
Group Icon
Group: Special Supporter
Car: Ford Taurus
Year: 2001
wow fantastic write up man! thanks
+Quote Post
arizonian
post Feb 13 2007, 11:23 PM
Post #22
Group: Members
Car: Ford Taurus
Year: 1996
Great write up! Shouldn't this be in the "Solutions to Common Problems/How to" articles? I realize this is not the most common probem, but it is an excellent "How to" article.
+Quote Post
SHOZ123
post Feb 14 2007, 10:24 AM
Post #23
SCT tuner
Group Icon
Car: Ford Taurus
Year: 1997
here's more good info about part numbers and updated components. http://www.shoforum.com/showthread.php?p=702956#post702956
+Quote Post
judaspriest99200...
post Sep 4 2007, 11:54 AM
Post #24
Group: Members
Car: Ford Taurus
Year: 1996
QUOTE(TrueBlue @ Jan 10 2005, 10:20 AM) [snapback]142248[/snapback]
I was going to ask you a question i'm having problems with vehicle running on 1st gear but not shifting to
second gear, it runs reverse but that's all. I'm buying a solenoid package that includes all five solenoids for $145.50, i'm just going to change all solenoids and see if that well fix problem any advice you could give me that may prove me wrong that solenoids won't be the problem and may need a transmission rebuild pls respond
+Quote Post
m4ff3w
post Sep 30 2007, 11:47 PM
Post #25
Group: Members
Car: Ford Taurus
Year: 1997
Just wanted to say thanks.
+Quote Post
3 Pages V   1 2 3 >
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
TCCA Custom Google Search Engine!
Loading
RSS Lo-Fi Version Time is now: 9th February 2010 - 08:03 AM
Taurus Car Club of America, TCCA, the Bull Logo and all other Club references are copyrights of the Taurus Car Club of America, Inc.
All Rights Reserved © 2003-2009
