Site Name : SHO Source Submitted By : LOUDSHO92 Submitted On: Feb 28 2009, 07:50 AM Clicks Counts: 4036
Description:
Parts for Taurus and Taurus SHO
Welcome to the TCCA, Please Register or Login to Remove this Message!
Hello and welcome to Taurus Car Club of America, the #1 resource on the internet for the Ford Taurus and Mercury Sable! If you are looking for information on the 2010 Taurus and Taurus SHO, you've come to the right place. We also specialize in all other years back to 1989! Feel free to browse around or jump right in to the discussions! We're sure you'll find what you need for your Taurus or Sable!
Like most online communities you must register and login to post and use other forum features in our community, but don't worry this is a simple and free process that requires minimal information. Remember to check your in box for the email validation after you register! Register Now
Trans Codes: A = MTX IV L = AX4S (1995+) T = AXODE X = AX4N
Also, does anyone happen to know for sure if the 2.5L I4 uses a chain or belt? IIRC pushrod engines usually come with a chain. And does anyone know if that motor is an interference motor?
Actually the AX4N Taurus final drives are all the same at 3.77 IIRC. It is the other vehicles the AX4N that have the different final drive. The 3.98 that I have comes out of a '96 Windstar tranny.
Taurus stands out like a wildebeest in plaid pajamas.
Group: Moderator
Car: Ford Taurus
Year: 2003
Engine: 3.0 DOHC (Duratec)
So does the po-po have a different drive ratio? I know the V6 SHO ATX has a different final drive ratio than the SLOs. Does anyone know which number that is?
Group: Members
Car: Ford Taurus
Year: 1998
which one does what for yuor car? does the 3.77 give more top end than the 3.98 or is it the other way around? does the 3.98 give better off the line performance than the 3.77 or is that the other way around??
I just checked both my 98s and they both have the 6R 3.98 gears. So I was just woundering which one does what.
Group: Gold Supporter
Car: Ford Taurus
Year: 1997
Engine: 3.4 Yamaha V8
QUOTE (D Man @ Aug 6 2006, 12:42 PM)
which one does what for your car? does the 3.77 give more top end than the 3.98 or is it the other way around? does the 3.98 give better off the line performance than the 3.77 or is that the other way around??
To restate what Paul said in a different way;
The higher the final drive ratio, the better the off-the-line acelleration. The lower the final drive ratio, the higher the top speed.
Frankly, I don't get above 120MPH often, so I will be getting the 3.98 gears in my SHO soon.
so if my 97 has the 3.77, it wont accelerate as well as a 3.98?
I googled the crap out of this subject and everything I found confused me
This topic isn't simple; depending on the gears in question, a lower gear may hurt or help performance in a given vehicle. In the case of our cars, as you raise the "final gear ratio" in the tranny, your zero to 60 and quarter mile times go down and your acceleration goes up. At the same time, your highway gas mileage will tend to go down. At a certain absurd point the performance equation will go the other way... if your tranny has to shift 3 times before you hit 55, you'll spend more time shifting than accelerating.
That depends on how well the tranny is set up too. My ATX will shift a lot faster than any manual. Maybe a 1/2 second total for both 1-2 and the 2-3 shifts.
