Member Number: 550
Well I was on my way to Seattle to visit someone and I stopped for gas at a Miristar (Wal-Mart) gas station. I got gas and went to restart the car but the battery was compleatly dead. Really pissed me off. I had been paying attention to the battery light because the guy I repoed it form said he thought the alternator was going out for some reason. Anyway, after over two hours of waiting, I was finnaly able to get my brother to come and give me a jump start. I got the car home and I shut it off in the driveway. Again, it was compleatly dead. I ripped that DieHard (and yea, evidently it did "die hard" just when I needed it!
In case you're wondering, by this time it was too late to make it to Seattle so I had to cancel my trip.
Ok, how about NO signature. |
Advertisement |
Member Number: 4536
A long time ago (in this galaxy), I had a battery that did that. You could drive the car (I don't remember what car it was), but sometimes it wouldn't start. What had happened was that one of the battery posts had developed an intermittent connection with the internal components. By pushing the battery terminal in various directions one could restore the connection and start the car.
Your post just reminded me of that. It must have been at least 10 years ago, when 1/2 of the TCCA members were about 6 years old.
It seems hot in the valley of Taurus... |
Member Number: 550
Yea, I tried cleaning the terminals and putting them back on, but this battery simply wasnt taking the charge from the alt. I tried it in a different car, same result. I took the Taurus to work today (with the other battery) and it did perfect.
Member Number: 407
If your battery light has been coming on lately, it's your slip rings in the alternator that needs replacing, what's happening is that at Higher RPMs the brushes are bouncing on the slip rings cause they have slowly changed shaped because the OEM alternator uses Copper sliprings, which is soft.
I've been having the same problem for close to a year now, I had the Alternator rebuilt, he replaced everything but the slip rings cause they looked fine to the normal eye, but when the car finally completely died on Tuesday (lucky I was on my way home and on;y a few blocks away) and wouldn't hold a charge, and I had to have my buddy with his truck tow it 5 houses away to my neighbors business Automotive Electrical Rebuilders (couldn't push it, cause we had to cross a busy 4 lane avenue with a grass median) we replaced the plugs on the alternator cause the tabs had broken and the connections felt loose, this didn't solve the problem, then he began to think and figured he's try the Slip Rings... Ding Ding Ding... PROBLEM SOLVED! took long enough, but I'm glad it's finally fixed! |
Member Number: 550
The bettery light has not been coming on except when the car is being started (as it should).
Member Number: 4536
However that is still good info. Several people have had the light coming on at higher RPMs, and this explains it nicely.
