Old 12-27-2004, 10:57 AM   #1 (permalink)
Member Number: 4494
dannytaylor is an unknown quantity at this point
after have been talked into by a friend in another company on my army base, i finally joined this site. I see a lot of people help each other on this site, great. I have a 1999 Taurus GL, nothing fancy, just a decent car for me, my wife and my 4 year old. My heater does not blow cold. When I turn the knob all the way to hot and when the car is completely warmed up, the heat just isn't hot like it used to be. Chris checked my car out and said to join this site and ask for help, he thinks my heater core may be clogged.
dannytaylor is offline   Reply With Quote
Old 12-27-2004, 01:03 PM   #2 (permalink)
Member Number: 4084
billyboy8 is an unknown quantity at this point
Is your temperature pointer on the "normal" range when the engine is warm? If the temp pointer is below normal, it's most likely the thermostat. If its in the "normal" range, it's probably a clogged heater core. Don't forget to check first if the radiator is full of coolant (when the engine is cold).
BILLY
2004 24V TAURUS SES
1990 3.0L TAURUS L
billyboy8 is offline   Reply With Quote
Old 12-27-2004, 01:35 PM   #3 (permalink)
Member Number: 3350
Nidan is an unknown quantity at this point
Yes, make sure the coolant reservoir is full. If it isn't, you probably have a leak. Top it up and see if you get heat. If it's full, get the engine nice and hot, and touch each of the heater hoses going into the heater core. They should both feel warm. If one is warm and the other is cold, or considerably cooler anyway, then the heater core is plugged. You'll need to flush it out, and that should get your heat back again. It's also possible that the blend door or blend door motor is damaged, but that's not very common on the taurus.
- Barenaked Ladies
Nidan is offline   Reply With Quote
Old 12-28-2004, 01:29 PM   #4 (permalink)
Super Moderator
chrism3784's Avatar
Member Number: 3432
Drives: 1998 Ford Taurus SHO, 3.4L Yamaha V8
chrism3784 is an unknown quantity at this point
Send a message via ICQ to chrism3784 Send a message via AIM to chrism3784 Send a message via MSN to chrism3784 Send a message via Yahoo to chrism3784
Got it to work. My friend Dan's heater indeed had a clog in the core. He had stop-leak in his car, it clogged his hater core. I unplugged the two hoses and sure enough, some wierd substance was coming out of it. Some metallic looking stuff. I hooked a hose to one side ran it into a bucket and I put a water hose to the other I turned it on high. All the stop leak crap came pouring out. Put it back together, and voila, his heater was greater then ever. MESSAGE TO ALL, never use that metallic stop-leak crap, unless you want to freeze. I'll probably need to give his car a good flush, and find where the leak is that caused someone to put stop-leak in it.
1988 Ford Taurus SHO Wagon (Being Built) - 1990 Ford Taurus SHO (Heading to Scrape Metal Soon) - 1995 Mercury Sable LS Wagon -
1991 Mercury Sable LS Wagon - 1998 Ford Taurus SHO
chrism3784 is offline   Reply With Quote
Old 12-28-2004, 01:54 PM   #5 (permalink)
Member Number: 30
TrueBlue is an unknown quantity at this point
Awesome. If you don't mind, I'm going to add this to the Solutions forum. Congratulations, and welcome to the .
2002 Chrysler 300M Special - 1968 Mustang Fastback - 1994 Subaru Legacy 5-sp.
ex-1995 MTX SHO - ex-1993 Vulcan GL
TrueBlue is offline   Reply With Quote
