Old 06-14-2004, 06:12 PM   #1 (permalink)
Member Number: 3140
Chaos is an unknown quantity at this point
2003 SES with 31k miles has recently developed shimmy when braking at 45 mph.
The tires although never rotated are in good condition , the car tracks straight and does not pull.
The front disc pads appear to be good for another 5 to 7 thousand miles.
Around town it does not exibit this problem . Most pronounced when exiting freeway and car slows down when braking.
What can be the problem ? or how should it be diagnosed correctly ?
Thanks for any help
Chaos is offline   Reply With Quote
Old 06-14-2004, 06:33 PM   #2 (permalink)
Member Number: 1930
Craddosk is an unknown quantity at this point
its under warranty, take it to the nearest ford dealership, tell them whats wrong, let them fix it.....you shouldnt have to pay a dime......
Speed or speed not. Just stay out of the way.
Craddosk is offline   Reply With Quote
Old 06-14-2004, 06:35 PM   #3 (permalink)
mwt
mwt's Avatar
Member Number: 1952
mwt is an unknown quantity at this point
Brake rotors are warped. This is a very common problem with the taurus.
Mike
btw you should rotate the tires every five thousand miles
94gl Vulcan totalled 4-01-04
New Paint coming soon
2000 SES Duratec Garage
mwt is offline   Reply With Quote
Old 06-14-2004, 06:41 PM   #4 (permalink)
jason8225
Guest
Member Number:
Posts: n/a
Mike
My bet is on warped rotors. Might not be covered under warranty though b/c rotors would be considered a "disposable" item.
Old 06-15-2004, 09:19 PM   #5 (permalink)
Member Number: 3140
Are there any preventative measures to take to insure longer rotor life ?
Does anyone know what the best rotor / pad combo is ?
The local Auto Zone had 2 choices for rotors : Valuecraft @ $19.99 each
Aimco @ $ 35.99 each
Can someone elaborate on this being a common problem with these cars ?
On a side note , this is my girlfriends car and she is a relatively tame driver.
But God only knows what goes on when I'm not around.....for all I know as she's cruising down that long mountain road , talking on her cell, applying make-up, drinking coffee as she puffs on a smoke maybe just maybe she's riding the brake !
Thanks again for any input !!!
Old 06-15-2004, 10:40 PM   #6 (permalink)
jason8225
Guest
Member Number:
Posts: n/a
Well, first of all...
I have Aimco rotors and Performance Friction Carbon Metallic Pads and have had them on for about the last 11k miles on my 2001 with no troubles at all and they are still working VERY well (that time includes a few road course sessions at Gingerman ). I absolutely love the combo.
For some reason warping rotors does seem to be a common thing in these cars.. <_< :shrugs:
Now, for maintenance - the only thing I can really tell you there is that if you are coming down from a higher speed to a dead stop, don't just let the car sit where it stops with your foot on the brake. This holds all the built up heat right against the rotor where it lies between the pads. Let the car drift a little so the heat isn't concentrated in one spot. I'm sure you notice people who kind of slowly creep while stopped at a traffic light - that's the reason I do it. Basically the main thing to prevent rotor warpage is to keep them cool - let them cool down by driving calmly, being easy on the brakes after you get off a highway exit ramp, etc. Hope this helps!
Old 06-16-2004, 09:03 PM   #7 (permalink)
Member Number: 386
Imacarbuff is an unknown quantity at this point
Normally, the brake rotors may not be covered under warranty. However, it's no secret that these cars have terrible rotors.
My '03 needed the rotors turned at 300 miles. I'm sure they will need to be turned again before I hit 20K. I would stay on Ford about this. My '99 had brake rotors, turned twice and replaced under warranty. You may have to complain right to the service manager....but you should not have to pay for something that is such a common problem to the Taurus.
BTW...they just replaced my hood insulation under warranty not too long ago-it was shrinking!
Imacarbuff is offline   Reply With Quote
Old 06-30-2004, 12:15 PM   #8 (permalink)
Member Number: 3267
chinanos1 is an unknown quantity at this point
On this post I've heard several replies about turning rotors and buying new ones. Is installing them a big deal? Doesn't seem like it. I've got 58K mi on my 2000SE and hav ethe same shimmy problem braking from high speeds. If they're warped, would turning really help? If cheapies are $20 a piece maybe new ones are the way to go.
chinanos1 is offline   Reply With Quote
Old 06-30-2004, 05:59 PM   #9 (permalink)
spridget's Avatar
Member Number: 140
spridget is an unknown quantity at this point
Warped rotors can be resurfaced for about $5-10 each. The surface is smoothed and straightened. As long as the rotors are still withing their serviceable range, this is the way to go.
I don't think the cars are at fault, I believe it is the driver. Jason8225 makes a good point. Holding all the heat in one area of the rotor can affect the surface. Making very hard stops can affect the rotor. Getting the brakes hot and spalshing through a puddle can damage the rotor. "Normal driving" is all relative to the individual.
Rotors are fairly simple to remove and/or replace.
RIP TCCA
'96 ES SHO -'98 Black SHO - '99 Graphite Blue SE - '99 3L SVT Contour
"If it feels safe, you aren't going fast enough." - Parnelli Jones
"A hardtop, with decent engine... and make sure it's got a big trunk!" Dwight - Sin City
"Old cars don't die, they become hot rods, and you know the thing about hot rods ........ they're NEVER "done"." - Rudedog (Rudy)
spridget is offline   Reply With Quote
Old 06-30-2004, 11:24 PM   #10 (permalink)
Member Number: 2397
henrysel is an unknown quantity at this point
Ford does seem to have a habit of rotors warping. I think it's because they just use less metal in the rotors to save on weight and improve gas milage.
I'd say they're not really worth turning, it'll make them thinner and even more likely to warp. The other thing that can cause warpage is putting on the lug nuts on too hard. If you have a shop do it, watch how they do it, do they use an air gun? Most of them time they just let the air gun hammer them on and it's usually set too high. I'd get a torque wrench and do it by hand.
Anyone know what the right spec is? On other cars I've had, it's ranged from 60-90ft-lbs depending on the type of wheel.
2001 Taurus SEL
24V DOHC
henrysel is offline   Reply With Quote
