Easy Heater Core Replacement For 2000 - Taurus Car Club of America : Ford Taurus Forum
Old 10-29-2009, 12:53 PM   #1 (permalink)
Member Number: 19752
dreamsteve has a little shameless behaviour in the past
Thumbs down
I have no idea if this will work on all years but I believe they should be about the same.
Watch and discuss please as I'm gonna be trying this in the coming weeks to see if it applies to a 2000.
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/http://www.youtube.com/watch?v=LsZoFoiJsdw"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/http://www.youtube.com/watch?v=LsZoFoiJsdw" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
If this works it will be a godsend to a large amount of people.
http://www.youtube.com/watch?v=LsZoFoiJsdw in case the embed doesn't show for you (not showing for me)
dreamsteve is offline   Reply With Quote
Old 10-29-2009, 01:26 PM   #2 (permalink)
ford_ses's Avatar
Member Number: 5162
Drives: 2001 SES Vulcan
ford_ses has a little shameless behaviour in the past
Thanks for the link That'll work exactly as he shows for any Taurus/Sable from 2000-2007.
This should be in Maintenance and Repair, though.
Here's a working embed:
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/LsZoFoiJsdw"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/LsZoFoiJsdw" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
Jim S. - Pittsburgh, PA
2001 Ford Taurus SES - Vulcan/AX4S, 160k and counting
1993 Ford Taurus GL - Essex/AXOD [GONE - 147k]
2002 Ford Escort ZX2 - Zetec/F-4EAT [GONE - 73k]
2010 Ford Fusion Sport - Cyclone/TF-80
2001 Toyota Camry LE V6 - 1MZFE/A541E and EXTRA BEIGE
1988 Pontiac Fiero GT - 2.8 V6/Getrag 282 5-speed
ford_ses is offline   Reply With Quote
Old 10-29-2009, 01:36 PM   #3 (permalink)
QUOTE (ford_ses @ Oct 29 2009, 12:26 PM)
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/LsZoFoiJsdw"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/LsZoFoiJsdw" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>[/b]
My apoligies. Please move it to the correct section. I'm not used to the forum software yet.
Old 10-29-2009, 02:14 PM   #4 (permalink)
Member Number: 12279
WHSEGUY28 has a little shameless behaviour in the past
Send a message via MSN to WHSEGUY28 Send a message via Yahoo to WHSEGUY28
Anyone know if this would work on a 1998 sable?
SOLD1998 Mercury Sable GS Toredor Red Metallic 3.0 Vulcan-AX4N 149,000 MilesSOLD
New car 2010 Ford Focus ses coupe black 2,000 miles
1999 Ford Taurus SE Comfort Sport Green 24vDuratec 138,000 miles
WHSEGUY28 is offline   Reply With Quote
Old 11-26-2009, 10:06 AM   #5 (permalink)
Member Number: 9021
Lapseal has a little shameless behaviour in the past
QUOTE (dreamsteve @ Oct 29 2009, 02:36 PM)
You are a GENIUS, It works like a charm.
Lapseal
Lapseal is offline   Reply With Quote
Old 12-16-2009, 09:37 AM   #6 (permalink)
Member Number: 17745
Drives: 3 Taurii .... 2001 Vulcan, 2003 DOHC, 2006 Vulcan
dandur805 has a little shameless behaviour in the past
WORKED LIKE A CHAMP. I had shoulder surgery on my left shoulder last week and I did the entire project with a winged arm. The only thing I did not do was to attempt to pull out the dash because I was affraid to pull on it. I waited till my grandson (17) got home from school and he helped me. NO PROBLEMO DUDE? Took the old one out and installed the new one. \
HINT: Two people to put back in place. One slides the core fwd slowly while the other makes sure the two tubes go into the rubber elbows in the engine compartment. Makes it much easier.
HINT 2: The core went in part way and then would not go any further. I went to the front and stuck my finger through the hole and found the end of the core nipple and it was ever so slightly hitting a cardboard? piece on the passenger side of the firewall. I moved it slightly and it was free. Then I went back inside and it slipped in the rest of the way.
Outsitanding instructions as given and used.
THANKS GUYS!
dandur805 is offline   Reply With Quote
Old 08-13-2010, 01:19 PM   #7 (permalink)
Member Number: 27456
Drives: 'kate' is a 2002, DOHC 3.0 SEL
taurus2002_taz has a little shameless behaviour in the past
Yeah Ford does manure like that, all the time. Similar situation on the Ranger as well. Having have worked there, I know that there are a lot of things they do that the public and government would cringe if they knew what I know. It was just like a soap opera there at Ford. I used to call it 'as the bolt turns' miss a lot of my friends there though
taurus2002_taz is offline   Reply With Quote
Old 08-14-2010, 01:17 PM   #8 (permalink)
Super Moderator
danhasenauer's Avatar
Member Number: 12182
Drives: a Taurus
danhasenauer has a spectacular aura about
This is almost identical to changing a G3 heater core. Super easy and major time saver. The bracket cutting step is the only exception. I didn't cut mine, don't recall if it was even there.
On a console equipped car, you need to remove a portion of the console where it connects to the dash.
'96 LX DOHC Moonlight Blue
RIP 'Ol Blue - 09/2012
danhasenauer is offline   Reply With Quote
Old 08-14-2010, 02:37 PM   #9 (permalink)
Member Number: 1771
You worked at Ford?
I like this heater core trick. Too bad you can't use it for the Evap core too...
Sold....
Scrapped...
Old 08-26-2010, 05:44 AM   #10 (permalink)
Default Yeah
I am fixing to meet with some people that still work there tonight. I guess on the news last night, there was another mention of closing the plant in St. Paul. They build rangers and mazda pick ups there. I am definitely new and green when it comes to dealing with A/C issues. When I needed to know things, I'd go over to repair in 201 and rap with the guys there. Those guys know EVERYTHING there is ever anything to know or look for. They see new trucks not start, Ect. I'm getting back to work now in the financial/insurance side now, pretty soon I will be able to buy the right tools for the job. Yeah it sucked because when they first laid off a whole shift, and threatened to close the plant in 2007, there were a lot of people that got to get that 'buyout' they offered and then still continued to work there for a little less than what they used to get paid and got to keep the benefits. I was hurt @ Ford in 2004, so they pushed me out the door. I wasn't given the option to continue to work there. That's life in corporate America...
