Member Number: 5922
The transmission filter and fluid should be changed as part of your regular maintenance routine, at least every 30,000 miles.
You will need the following: 1. A filter change kit: ![]() 2. A socket set: ![]() 3. A drain pan (not pictured) 4. Replacement transmission fluid. The manual suggests a Mercon V type fluid. ![]() Step 1. To begin, put the vehicle up on ramps or raise it with a jack and securely support it on stands. Step 2. Direct your attention to the transmission drain pan. It is located aft of the oil drain pan underneath the car. ![]() You will have to examine the drain pan to determine which model transmission you have. As you can see, I have the AX4N model. There are several different models on the Gen 3, and they do not have similar gaskets. I do not know if the filters themselves differ from model to model, but the prices are all about the same so make sure you get the right one. ![]() Step 3. Using your 8mm socket, carefully loosen each bolt about 1/4 of a turn all the way around. ![]() Step 4. Remove the bolts on one side of the pan. Fluid will start to drain from the pan. Make sure you have a pan below to catch the falling fluid. ![]() As you remove the bolts, more fluid will start to flow. ![]() Step 5. Once the pan stops draining, remove it completely, and inspect the old filter. ![]() Step 6. Make sure you also remove the filter seal inside the housing. CAREFULLY pry it loose with a pair of needle nose pliers. ![]() ![]() Step 7. Examine the empty drain pan. ![]() Step 8. Remove the old gasket. ![]() Step 9. Inspect the magnet. This is designed to catch loose metal through the transmission system. ![]() Step 10. Using a high-flash point solvent (such as brake cleaner or carb. cleaner) clean out the drain pan. ![]() Step 11. Allow to air dry. ![]() NOTE - the drain pan holds about 7-8 quarts of fluid. There's a transmission reservoir that holds another 4-5 quarts. At this point, you could use additional fluid to empty out every last bit of the old fluid. Is this necessary? I personally don't think so. The new fluid combines with the old, and as long as you keep up with the regularly scheduled filter changes you'll have replaced the old fluid over the length of a couple of changes. But what do I know? I've only done this 11 times on the same transmission. Step 12. Install the new filter. Make sure it fits just as the original did, there are some "sprockets" designed to brace it against the transmission cooling tubes and it must line up. ![]() ![]() Step 13. Reinstall the drain pan. Slowly tightening the bolts all the way around. Do not overtighten. Step 14. Using a funnel, refill the transmission fluid. ![]() I suggest filling with 6 quarts, then going through with the process of checking the fluid, and refilling in increments. You may need as little as 7 quarts, or as much at 8. I believe total system capacity is about 12.5 quarts. Be sure the properly dispose of the old transmission fluid. DO NOT DUMP IT IN THE WAL-MART PARKING LOT AT 3AM. |
Member Number: 14911
that is Awesome.... I was scared to do anything with my tranny and I just had it serviced...I wish I waited to see ur post...
#3 (permalink) | |
Member Number: 10617
2005 Vulcan - 45K - Mine (Daily Driver) 2007 Fusion V6 FWD - 20K Dad's 2008 Escape Hybrid FWD - 20K - Mom's |
Member Number: 11956
Drives: 1995 Gen 2 yo!
Sticky it!!!
![]() Clubs: TCCA-WEST COAST and SHO-CAL |
Member Number: 5766
excellent tutorial.
-Andrew ![]()
Member Number: 140
Good write-up. You can tell that trans has been well maintained... the old fluid still looks good.
(add the torque specs for the pan bolts and it will be a great write-up)
RIP TCCA ![]() '96 ES SHO -'98 Black SHO - '99 Graphite Blue SE - '99 3L SVT Contour Find me at the best Taurus and Sable owners online resource. |
Member Number: 11699
Great preventive maintenance! Nice and clean inside. Is that the fuel filter in the back ground? Do you have a trans fluid cooler? I use the same fluid in my Sable, works very well.
Member Number: 1808
Drives: 2007 Mazdaspeed 3
Rep Power: 17 ![]() |
You didn't need to replace the pan gasket - that's a reusable rubber gasket. You only need to replace the older style cork gaskets. Excellent write-up though!
- Daniel Current: 2002 Pontiac GTP 40th Anniversary Edition 2007 Mazdaspeed3 Past: 1997 V8 SHO Silver Frost - ELISJOY 1997 V8 SHO Ebony Satin - RIPElaineRIP 1997 Vulcan GL - RIPSuzanneRIP 1990 Vulcan Sable - NONAME |
#9 (permalink) | |
Member Number: 3681
BTW, nice write-up Harvey Birdman...should give more people the confidence to do it themselves.
'99 SE (<strike>now my sister's</strike>) traded in for a RAV4 '96 GL (my niece's) '03 Marauder (black. supercharged. mine) '03 Marauder (silver. mild mods. wife's) '68 Skylark convertible (mine. owned since '78) |
#10 (permalink) |
Member Number: 8940
Nice cone filter and write up...
