Erratic Fuel Gauge Fixed (ffv’s Only) - Taurus Car Club of America : Ford Taurus Forum
post #1 of 23 (permalink) Old 11-30-2006, 11:33 PM Thread Starter
The fuel gauge in my ffv was inaccurate. It would occasionally display the right amount of fuel in the tank but most of the time it was way off. After searching I came across this page that had a cheap and easy fix.
Parts Needed:
Part #YF1Z-14A069-AA wiring ASY (I forgot the actual part name so I'll call it module) $40 at you local ford dealer
Tools needed:
8mm nut driver
7mm nut driver
radio removal tools $3
Time to complete: 20 minutes
STEP 5:
Tighten everything back up and reconnect the battery. Start up the car and observe the fuel gauge to see if it reflects the right amount of fuel in the tank.
I'm told they will only need 30 to 60 minutes to install. So I tell them I can wait. 4 hours later I see 4 tech's around my car scratching their heads. Not a good sign.
freshv6power is offline
post #2 of 23 (permalink) Old 12-03-2006, 10:55 AM
Just replaced this yesterday. Fixed my problem. I posted an article yesterday and took photos while replacing this. No need to disconnect battery (so long as keyswitch is of)or take the climate control/radio assembly out. Sensor is accessible from underneath, but it is a bit tight to get to.
sh01443 is offline
post #3 of 23 (permalink) Old 12-03-2006, 11:03 AM
mwt
mwt's Avatar
Anytime you are doing something like this you should disconnect the battery simply for safety's sake.
There is no telling what a screwdriver or any other tool will come in contact with if it slips.
Mike
94gl Vulcan totalled 4-01-04
New Paint coming soon
2000 SES Duratec
mwt is offline
post #4 of 23 (permalink) Old 12-04-2006, 02:31 PM Thread Starter
That's because you have a Gen4. On the Gen 3's it's right behind the radio unit.
post #5 of 23 (permalink) Old 02-16-2007, 02:36 PM Thread Starter
solutions to common problems or wiki?
post #6 of 23 (permalink) Old 03-04-2007, 06:32 PM
ffvulcanpowah's Avatar
Send a message via AIM to ffvulcanpowah
Yes!!! Finally a solution to my posessed fuel gauge! I was so worried I would have to change out my sender (though, who knows, I still might have to ), but I'm certainly going to give this a shot and see how it works. Thanks a mill!!
"YOU WILL ALL BOW DOWN TO MY AWESOME SHO THAT IS REALLY JUST A TAURUS WITH FIDDLY BITS AND TWO MORE CYLINDERS!!!11ONE" -Dan
"If you got the lack of sense to mod a TAURUS you should be allowed to cut a hole in your hood. Let everyone see the extent of your madness" -Luke
ffvulcanpowah is offline
post #7 of 23 (permalink) Old 03-06-2007, 11:52 AM
Parts Needed:
Tools needed:
8mm nut driver
7mm nut driver
STEP 5:
You stated the repair for a 3/4 generation vehicle with FFV, is it a similar fix for a 1990 model (generation 1) with the 3.0 OHV motor (it does not have FFV)? I looked up the part number you provided and it is listed as "wire asy-Fuel tank g." Thank you for your assistance.
Taurus90Taurus05 is offline
post #8 of 23 (permalink) Old 03-19-2007, 12:51 PM Thread Starter
Sorry this reply is late. I believe this part is only for FFV's since there are other parts in the system that work in conjuction with it.
But there may be a similar part for non-FFV versions. I don't really know.
UPDATE
It's been 3 months since I did this repair and so far there have been no problems.
post #9 of 23 (permalink) Old 03-19-2007, 01:00 PM
DrinkMore's Avatar
Send a message via AIM to DrinkMore Send a message via MSN to DrinkMore Send a message via Yahoo to DrinkMore
Anyone make this a WIKI yet? It should be incase new people come in with the issue.
DrinkMore is offline
post #10 of 23 (permalink) Old 04-17-2007, 09:05 PM
lorsod's Avatar
I also tried this on my 2000 Taurus FFV and it worked great. Best $43.00 I have yet to spend on this car. Was worried I would have to remove the gas tank. My gauge said 1/3 tank when purchased in Feb. but then went to way overfull and hadn't moved till I replaced this part. Great write-up and thanks for the info.
2000 Taurus SE FFV
lorsod is offline
