Old 02-15-2006, 12:38 PM   #1 (permalink)
RoGuE's Avatar
Member Number: 5930
RoGuE is an unknown quantity at this point
I realize there are numerous posts about this and I apoligize but I just want to be sure about everything.
Either this weekend or next, I am going to do the tune up and I just want to make a list of everything I have to do with questions.
Spark plugs- What is the part number for the best Motorcraft plugs (is it fine wire plugs that are the best)?
What kind of dielectric grease should I use on the wire boots?
Do I put something on the threads when I put the new ones in?
Wires- I figure they should be changed so what wires should I use?
Thermostat- Part #? Should I replace it?
PCV Valve- Part #? Should I replace it?
Should I clean the MAF and IAC and throttle body or leave it alone since it works fine?
The coolant and transmission flush will be done at the dealership. I have also had a problem in the past where coolant leaks out of the plastic tank on the side of the radiator when the back of the car is higher than the front parked on an incline. Should I get this fixed or leave it alone? I haven't had any problem since I have been parking on a level surface.
-Jonathan
RoGuE is offline   Reply With Quote
Old 02-15-2006, 01:52 PM   #2 (permalink)
Member Number: 4863
sfontain is an unknown quantity at this point
I'm not going to deal with all the '[ quote ]' busiess. See below your questions. I don't have part numbers--call a dealership and ask.
Don't know. If you are buying from a dealership, they can look for it. If you want to use Motorcraft, OE should be fine unless you have a really good reason otherwise. Autolite double platinums are probably the best aftermarket alternative.
Any kind. They sell it in little packets for about $1 at most parts stores. "Spark plug grease" or "Dielectric grease."
You -can- use anti-seize. If it will be 5 years before you do a swap again, this might not be a bad idea.
OE. They will cost you, but I have to highly recommend that you pay for them.
If you're doing coolant, it won't hurt. Preferably OE. I guess that mostly, these either work, or they don't; if you do it now, you avoid having it get stuck 5K after you change the coolant.
Yes. Preferably OE.
Shouldn't hurt, but use a cleaner that doesn't leave a residue for the MAF. I think brake cleaner is recommended for the MAF. TB cleaner will work on the IAC.
Don't know, sorry. If you don't deal with it, you need to keep a diligent eye on your coolant level and temperature guage.
sfontain is offline   Reply With Quote
Old 02-15-2006, 06:58 PM   #3 (permalink)
Member Number: 6212
kellyinkc is an unknown quantity at this point
Which engine do you have. I have the 99 3.0 Vulcan. The plug number from dealership was AWSF32FMF4. Keep it OE. That what I have learned.
Kelly
kellyinkc is offline   Reply With Quote
Old 02-15-2006, 07:07 PM   #4 (permalink)
Member Number: 899
godspunk32 is an unknown quantity at this point
I have used Bosch plug wires on my Duratec with success and a Stant thermostat. Both have worked out very well, and will likely save you some money over OEM.
JR
godspunk32 is offline   Reply With Quote
Old 02-15-2006, 07:19 PM   #5 (permalink)
RoGuE's Avatar
Member Number: 5930
Kelly
This is confusing me. I have read so many different part numbers for Motorcraft plugs: AGSF32FM, AGSF32FMF6, and now you say AWSF32FMF4. Which one is it?
Also, are Motorcraft plugs available at Autozone or just the dealer?
-Jonathan
Old 02-15-2006, 07:32 PM   #6 (permalink)
Member Number: 899
I think Autozone only stocks OE replacement plugs, like Autolite or Bosch. You most likely need to go to the dealer for Motorcraft plugs.
JR
Old 02-15-2006, 07:43 PM   #7 (permalink)
Member Number: 3147
crazy_canadian is an unknown quantity at this point
Send a message via AIM to crazy_canadian Send a message via MSN to crazy_canadian Send a message via Yahoo to crazy_canadian
hte vulcan is now running on the same set of Bosh Platinium +4 sparks plug for like 18k and it runs awesome. I have also some Motomaster wires, but who cares? its from canadian tire
'95 SHO MTX Deep jewel green with Tan interior
1/4 mile : 15.07 @ 96.4 MPH
76k miles
-Catless Y-pipe
-Summit Turbo mufflers
-K&N Panel Filter
-Alarm & Remote start system
** Soon to be installed : Eibach springs with koni struts, G3 SFB, SHONUT Reinforced MM.
'93 SHO MTX Emerald Green with Black interior (Parts Car)
160k miles
-2 engines, 3 transmission and lots of spare parts
Eastern Canada Chapter Vice-President
crazy_canadian is offline   Reply With Quote
Old 02-15-2006, 07:56 PM   #8 (permalink)
Member Number: 4863
JR
I think so too, generally.
If you are buying a bunch of stuff and you can wait, it might be worthwhile for you to check out some websites too. I've never ordered from any of these places, but I think rockauto.com and genuine-ford-parts.com are supposedly alright.
Old 02-15-2006, 08:17 PM   #9 (permalink)
Member Number: 899
Rockauto.com is awesome!
JR
Old 02-15-2006, 08:53 PM   #10 (permalink)
mooby's Avatar
Member Number: 3283
mooby is an unknown quantity at this point
a good set of bosh on a 99 3.0 L
a set off wire with the best warenty
some grease
some copper plug
pcv valve ford
thermostat ford
and for the maf you use some electronic contact cleaner it does not leave any residu
for the iac i use some carb cleaner since it really remove any carbon or varnish
for the coolant flush it ok anywhwere is the same oil and prestone so ....
but for the tank get this fix i know it a big prb it have a big tendency to rip open
mooby is offline   Reply With Quote
