How To Flush Your Tranny At Home - Page 29 - Taurus Car Club of America : Ford Taurus Forum
post #281 of 293 (permalink) Old 08-23-2012, 02:18 PM
Why go out and spend money for something that isn't needed, and then have to find space to store it? Just as easy to drop one side as the other, only the one way will wind up with less mess. Personal preference always comes out on top. Just a suggestion, not a contradiction. Thanks to the TCCA for the good flush procedure.
killermrob83 is offline
post #282 of 293 (permalink) Old 01-29-2013, 11:59 AM
Spam links for pics? Nice...not.
hardknoxfirst is offline
post #283 of 293 (permalink) Old 05-26-2013, 11:55 PM
In step # 2 you stated to place the car on jack stands. At this point the vehicle would be much higher in the front than the rear. Would this have any effect on the amount of fluid that could be removed? I asked you this because I have access to a old time drive over pit that was somewhat common in old home garages many years ago.
vmaxim is offline
post #284 of 293 (permalink) Old 06-03-2013, 04:24 PM
Talking
New member here,, Just did all this, this afternoon, per Dlc360's recommendations,, got the car up, unhooked cooling line, started car, drained into big bucket, stopped engine, put in 5 qts. started car, flushed, stopped motor, put in 5 more qts. and flushed,, stopped motor, THEN dropped pan, replace filter, cleaned pan, AND MAGNET, put everything back per the instructions I read about ON THIS COOL SITE!! refilled with merc V. and that's it!! A super big thankyou to all that expressed help on these pages, btw, its a 2000 sel, duratech, with 124,000 runs real good! I prolly would not have done this, if I hadn't joined just a few days ago....... regards... Greg
Triton3.5 is offline
post #285 of 293 (permalink) Old 06-04-2013, 01:52 PM
dlc360's Avatar
Send a message via Yahoo to dlc360
If you have a pit available use it, that's the safest way to get under a car. Myself, When I did the trans service I always jacked the whole car up. When working under a car, I like to raise the whole thing just for more clearance & you can check other things under the car at the same time.
Thanks Triton3.5 for the compliment. I used this same write up on my cars. The original poster gets credit for that.
DLC360 2003 Taurus SE Wagon.
A daily driver that thinks its a show car.
December 2007 COTM, August 2011 ROTM
Aug. 2010 T.S.O.C. COTM & 2010 T.S.O.C. COTY
24 Time Award & Trophy Winner
03/31/2006 - 04/11/2012
Presently driving,
2011 Mercedes Benz C300 4matic Sport 3.0L V6
2011 Audi A3 5 Door (mini wagon) 2.0 turbo 4cyl.
1985 Corvette with 1992 LT1 V8 (400hp)
dlc360 is offline
post #286 of 293 (permalink) Old 10-08-2013, 10:59 PM
Made an Ass Out of Myself
Boy did I make an ass out of myself on this one.
I did this and as I was refilling the tranny fluid after reconnecting the tranny return hose, it appeared to be leaking from the pan. I had the reuseable gasket and reused it torquing the bolts to 106 inch pounds per the Hyanes Manual.
I had purchased a new gasket because I just purchased this car used and did not know if the gasket was the reusable one. I thought the old gasket was bad so I dropped the pan again to replace the gasket with the new one.
I installed the new gasket and as I was refilling, it started leaking again. I double checked my torque again and wiped away the leaking area and it stopped. I was doing a quart at a time and I thought it was odd that it was leaking with just a couple quarts when it shouldn't have even reached the height of the gasket.
So then it hit me. I removed the funnel from the fill hole and sure enough, I could see tranny fluid on a hose below. Apparently, even though I was only doing a quart at a time, I was filling it too fast and it was coming out of the fill tube and leaking down in a way that made it drip right off one side of the pan. That's why it stopped after I wiped it and why it started after only a quart or two.
I then refilled slowly and the "leak" never came back.
I wasted a lot of time, fluid, and a gasket I could have returned for a refund on this. Had to run to two Walmarts to get more fluid (one Walmart had one quart on the shelf). My funnel wasn't very big and I thought I was pouring slowly enough as I seem to recall one poster who had the same issue but I thought he had a large funnel.
So what would have taken 3 hours ended up taking 8.
Joe_Blough is offline
post #287 of 293 (permalink) Old 10-08-2013, 11:10 PM
Dee-ta-dee, lol!!!
sheila is online now
post #288 of 293 (permalink) Old 10-08-2013, 11:16 PM
Play Nice or Don't Play
jag1959's Avatar
Engine: 3.4L Yamaha V8
jag1959 is offline
post #289 of 293 (permalink) Old 10-08-2013, 11:20 PM
Another note. I pumped out 4.5 quarts when I ran the engine and got another 1.5 quarts when I dropped the pan, for a total of 6 quarts. I was expecting to get close to 13, but I didn't check the level before I started.
I then put 14 quarts in (probably 2 or 3 quarts more than I needed but the fluid came out dark brown like oil so I wanted to be sure it was flushed well) but only pumped out 11 before the flow stopped.
I then reconnected the return line put another 2 quarts in which should have given me 5 quarts in. I then noticed leak and dropped the pan to change the gasket and got another 4.5 quarts out, leaving me with .5 quarts in.
When I went to refill everything, It took only 7 quarts before going to the top of the cross hatch pattern on the dip stick.
So it looks like there is always about 6 quarts in the tranny even after pumping it out and dropping the pan.
I was confused by the original post that said add ten quarts and pump until it stops or turns red and then add 5 quarts and check level, not realizing there is always about 6 quarts remaining in the tranny (which makes sense if he said only add 5 quarts and then check the level).
I almost put 8 quarts in before checking, assuming I was going to need about 12 or 13 quarts but I stopped at 7 quarts.
The fluid level is a little above the top of the cross hatch pattern. Maybe 1/8 inch. Do I need to pump some out to get it in the crosshatch pattern?
post #290 of 293 (permalink) Old 10-09-2013, 01:10 PM
If it's only ~1/8" above the crosshatch when checked warm, idling in park, I wouldn't be concerned.
Closed Thread
