I got trouble. I need help. - Page 2 - Taurus Car Club of America : Ford Taurus Forum
 1Likes
post #11 of 17 (permalink) Old 03-08-2017, 04:27 AM Thread Starter
I've had this car for over 10 years and as best I can recall, there has always been some sort of visible vapor and moisture at the exhaust pipe end until it really warms up. I had asked about it before in other places and was told it wasn't abnormal.
Lil_Red_Wagon is offline
post #12 of 17 (permalink) Old 03-08-2017, 04:30 AM Thread Starter
Everything I'm reading everywhere I can find talks about leaks visible in one way or another, but I can't find anything about the rough idle (puttering) being related.
post #13 of 17 (permalink) Old 03-08-2017, 08:56 AM
Rent or borrow a coolant system tester. It will tell you if there's a head gasket leak (and other coolant system leaks.) If you can't get one, drive the car to a service center like Midas, Meineke, Firestone, or whatever there is locally. Once the car cools down, it's a 2 minute job and probably shouldn't cost more than $20.
Absent any evidence of a leaky head gasket (coolant on the floor, or the chocolate milk sludginess in the motor oil) your problem could be an ignition fault, like a bad plug, wire, or a bad coil. It could be a vacuum leak--mine had a cracked pcv hose/elbow. It could be an egr fault. Could even be a weak fuel pump or clogged fuel filter.
I don't know why I should dislike you. Whatever it is you've been forgiven! Hope you get it worked out.
2001 SES Wagon. 210k and strong running.
Brian in Tucson is offline
post #14 of 17 (permalink) Old 03-08-2017, 09:53 AM
Parts stores loan/sell kits that determine the presence of combustion gases in the coolant.
post #15 of 17 (permalink) Old 03-08-2017, 10:16 AM Thread Starter
I've got Advanced Auto, AutoZone and a few others, but they're not real close. I'll check and see what they have.
I've seen fluids on the garage floor, but I know there's a rad leak and I've had PS leaks and a couple of other issues.
Fuel pump was replaced 6 or 7 years ago.
Could be a vacuum hose I guess, but I wouldn't know how to find that.
Had an '89 Cougar with the same engine that need a head gasket, but I can't remember if the symptoms are the same. Seems to me they told me at that time that the break was off one of the exhaust ports and would not have shown in the coolant. But that was a long time ago so I'm not sure.
As far as taking it to a shop for testing, I don't have one within 15-20 miles over hilly, country roads and I don't know if it's safe to drive this that far without the risk of further damage.
post #16 of 17 (permalink) Old 03-09-2017, 09:06 AM
You don't seem to be able to do any of the things we've suggested. You need to pressure test the system to see if it's leaking & where. You can't go get the tools at Autozone or Advanced, and you can't drive it in for diagnosis and repairs.
Looks like you're screwed. Sorry. (God helps those that help themselves.)
post #17 of 17 (permalink) Old 03-15-2017, 02:28 PM Thread Starter
Found a Lone Yokel Redneck shop that hadn't been around long. Not too many people knew of him or could say whether he was any good or not. Figured he probably knew a little more than I did, so I gave him a shot.
He pulled codes in his bigger machine and didn't see anything suspicious so he figured it just needed a good tune up and checkout, and I left it with him.
He ran all the tests and didn't find any problems in compression or exhaust gasses in coolant, etc. Changed pretty much everything in the ignition system as far as wires, plugs, cap, rotor, etc. and tested whatever else he could. Cap and rotor show some signs of wear, but he's pretty sure the main issue was the one wire that had apparently laid across the exhaust manifold and shorted out. That would certainly account for the misfiring and probably happened during that last couple of miles when it suddenly stated acting so bad.
None of his tests indicated a head gasket according to him.
It ran fine on the way home and idled smooth in the driveway for a few minutes. It may be a few days before I drive it far enough to see how it runs over a longer period.
Name:	Taurus Rotor & Cap.jpg
ID:	188754   Click image for larger version
2000 Ford Taurus Trouble in Transmission Town Richard Franke Maintenance and Repair 6 12-12-2015 11:42 PM
2004 Taurus (Vulcan?) has trouble starting TrainSlinger Maintenance and Repair 7 04-21-2015 03:00 PM
P1401 Trouble Code mhill012 Engine and Drivetrain 10 03-13-2015 05:01 PM
Trouble Bleeding Air from Power Steering System jrandallc Maintenance and Repair 1 02-14-2015 01:47 PM
Trouble shifting into 3rd gear bailey53 Maintenance and Repair 1 05-23-2014 08:57 PM
