Another Weird Idle Surge Issue, Help? - Taurus Car Club of America : Ford Taurus Forum
post #1 of 2 (permalink) Old 10-15-2016, 01:56 AM Thread Starter
Okay awhile back I had issues with a quoted idle down surge, not a normal surge, it turned out that the IACV, waa noon motorcraft so it caused the car to idle hunt and waste gas and be annoying where it would surge from like 700 rpm down to 600 back to 700. Replaced the old IACV and problem went away.
Well now, fast forward like 7 months I started noticing while parked I was getting down surges again, but this time in less obvious fluctuations, note ours idling down from around 720 rpm to about 680 frequently idle hunting, and idk why this time, coyly I be looking at replacing the IACV with a motorcade part? Or what else might cause an engine to "down" surge and it also causes the car to shake ever so slightly.
FreakyFreak is offline
post #2 of 2 (permalink) Old 10-15-2016, 07:13 AM
Watch for misfire, and A/C cycling. If you turn your A/C off like "vent" and it fixes the idle range, then you have the answer. Misfire should give a CEL.
Others causes, PCV, vacuum leaks, fuel pressure as in filter and pump.
The system adds some air/fuel with the IAC when the A/C clutch is commanded. It assumes the A/C pulls the standard load on the engine.
Weird Start Issue Suddenly? FreakyFreak Maintenance and Repair 1 04-14-2016 07:22 AM
1995 Sable LS idle issue at times driving me nuts! imabadczech Maintenance and Repair 24 05-19-2015 07:40 PM
1987 Taurus Idle Issue!!!! Help!!!!!!!!! 89TaurusMan Maintenance and Repair 11 11-28-2013 02:56 PM
Idle issue w/AC on mrscot Maintenance and Repair 16 08-15-2013 07:23 PM
97' SHO, code P0411 and weird idle when hot. Nick3.0L Maintenance and Repair 11 05-23-2013 09:44 PM
