01 DOHC (AX4N) RPM bounce + AC on - Taurus Car Club of America : Ford Taurus Forum
post #1 of 17 (permalink) Old 09-10-2016, 03:28 AM Thread Starter
Hi, I have two perfectly identical 01 Ford Taurus (SEL DOHC AX4N)
both are regularly serviced with OEM fluids and filters
one has 100K on the ODO <--------- This one has steady RPM no matter AC on /off (and clutch engage), and always sitting on 600-650 IDLE no bouncing
the other has 35K on the ODO<----- here I got a 100-200RPM boost / bounce every time the AC clutch engage, nothing major but its cycling like this every 5-7 seconds. other than that the RPM are sheer steady, (till the clutch cycle again) read on the forum - its just the PCM compensate for loss of power by the AC compressor
which one acts normal ?
Thank yall!
DarronSEL is offline
post #2 of 17 (permalink) Old 09-10-2016, 07:12 AM
Thank yall!
Your PCM is a flip phone technology, not a 'smart' phone. It gets inputs from various load expectations and adds IAC to match the load and keep the rpm steady. The tranny, PS and A/C are rpm matched. If the load is less than expected the rpm will increase. My '01 did that a while before I sold it. It means the A/C is not up to par. My '03's (wagon and sedan DOHCs) are within a needle width.
If the IAC is draggy, the RPM will drop with each of the key inputs. Put in gear and the rpm will drop. And all of them will be off. Only the A/C and it is the A/C at fault.
(I miss my flip phone)
chartmaker is online now
post #3 of 17 (permalink) Old 09-10-2016, 07:37 AM Thread Starter
Ah! Replaced the IAC with OEM motorcraft, not even a slight change ..
What's up with m AC compressor?!
If it's not "satisfying" the PCM should it be replaced ? (It works perfectly though ..)
post #4 of 17 (permalink) Old 09-10-2016, 07:56 AM
repairman54's Avatar
A/C is cycling frequently? Only 2 things cause that. Undercharged or Overcharged refrigerant.
In isolated cases other components but low on 134a is the most common.
RPM bounce is normal, tachs in these cars can vary, not exactly precision gauges.
As chart said rapid cycling of a/c and flip phone PCM results in a system lag so it may not be getting a chance to "settle" in.
John
'11 Tahoe
'09 Malilbu LS
'03 Sable LS 24v
'05 Sable 24v son's
'01 FLHR
Ski Doo's Sea Doo
Previously enjoyed vehicles
'07 Mustang GT 3 pedals
'89 S10 Blazer 4x4
'75 Cordoba
'68 GTO
'68 Chrysler Newport 2dr
'67 Chevy Caprice 2dr
'67 Chevelle
'65 Bonneville
'65 Chevelle
'64 Olds Jetstar 88
repairman54 is offline
post #5 of 17 (permalink) Old 09-10-2016, 09:04 AM
Good call on 'short cycling'. Your car is talking, asking for HELP!
I took my IAC (looks clean) out and wiped the shaft where it goes through the seal at the solenoid end with a Q-Tip, drop of light oil, move the piston with a Q-tip and then wipe off the excess oil. Made a difference. I think mine is a close to perfect as it gets. But I am paranoid. If a few minutes effort make it better, why not?
And the PCV makes a difference, only OEM, and the elbow. PCV can cause low or high idle. Been there.
post #6 of 17 (permalink) Old 09-10-2016, 09:18 AM Thread Starter
That's interesting, the entire IAC area is really nice and smooth + brand new OEM IAC in place, PCV was never replaced in 16 years, but one would think if malfunction should through a cel code or act funny no matter AC on / off ..
Would you replace it ?
post #7 of 17 (permalink) Old 09-10-2016, 09:27 AM
Yes, if 16 yrs. old, lol. Get a Motorcraft pcv valve from Rockauto online. Preventive maintenance. Carefully inspect pcv hose/elbow assy. when replacing. Idle may still fluctuate if a/c issues are present.
post #8 of 17 (permalink) Old 09-10-2016, 02:01 PM Thread Starter
Hi Thanks, will do!
as a side note my Idle RPM doesn't fluctuate nor bouncing etc ..
its very steady, then the AC clutch kickin in and the Idle raise about 100-200 rpm on top of normal idle speed of 600
and so on every 5-7 seconds ..
needless to say none of this happen when AC is off ..
any idea what could it be ?
just lack (=or too much) of 134a could in theory cause this ?
post #9 of 17 (permalink) Old 09-10-2016, 02:29 PM
Rapid cycling of the a/c is the issue. Most common is lack of or low 134a. Compressor cycles on low pressure cutoff switch. It's function is to protect the compressor from lack of refrigerant.
Cutoff is on low pressure side of the system, usually shuts off compressor when low side pressure drops below 20 psi. .
System needs to be checked and on a 15 yr old car it's normal to have a miniscule leak and loose some over all this time.
IMO your system is cycling on the low pressure cut off. When compressor starts it draws down the equalized system pressure to the cutoff limit stopping compressor, then pressure will rise back up and trigger the cutoff to restart compressor and back down it goes again to the low limit cutoff. That's why it keeps starting and stopping endlessly and too quickly, PCM is not designed for this scenario, on a hot day compressor will run endlessly to provide cooling.
System pressures need to be checked first before wasting money on other engine components.
Money spent on a IAC would get a set of A/C gauges at Harbor Fright, about $50
John
'11 Tahoe
'09 Malilbu LS
'03 Sable LS 24v
'05 Sable 24v son's
'01 FLHR
Ski Doo's Sea Doo
'89 S10 Blazer 4x4
'75 Cordoba
'68 GTO
'67 Chevelle
'65 Bonneville
'65 Chevelle
'64 Olds Jetstar 88
post #10 of 17 (permalink) Old 09-10-2016, 02:34 PM
Year: 2004
Have you reset and let the PCM relearn it's idle strategy since all the maintenance you've done? And was this problem there or different before you did the maintenance?
There's a separate idle strategy with and without AC.
rjacket is offline
AX4S/AX4N Bellhousing differences >> Hoping to bolt up my 3.8 + AX4N. DMX Engine and Drivetrain 8 10-12-2015 05:23 PM
Vulcan to DOHC swap gen 4 engine to gen 1 car ZAFH Engine and Drivetrain 21 11-22-2014 08:12 AM
AX4N HELP Dbhill42 Engine and Drivetrain 24 09-02-2014 09:31 PM
Will my tranny bolt up? AX4N... help...please? taurusflip Maintenance and Repair 17 11-24-2013 09:27 AM
DOHC for Vulcan swap unclejunk Maintenance and Repair 21 04-27-2013 07:52 AM
