Can bad oxygen sensors cause issues with the transmission? - Taurus Car Club of America : Ford Taurus Forum
post #1 of 11 (permalink) Old 09-04-2013, 12:31 PM Thread Starter
I have a 2002 Taurus and am looking for some directions. We replaced the split hose going to the pcv valve a couple of months ago. At that time when the codes were pulled the oxygen sensors where also a suspect. We did not replace them at that time. Now the car is getting really unreliable. When the car is driven first thing in the morning it is not wanting to go into a gear. Once it decides to shift it will shift in/out of the gear several times. It will run once it gets going but I have noticed when I slow down to turn a corner it takes a few seconds for the transmission to shift to another gear. This transmission was rebuilt in Feb 2012. The other night going down the interstate the exclamation light started flashing. When I restarted the car after getting to my location the light went out. Also I have noticed that when I am stopped the speedometer is jumping occasionally. Can all this be caused by the oxygen sensors?
thanks for any help.
smurp1835 is offline
post #2 of 11 (permalink) Old 09-04-2013, 12:38 PM
bittyboy3's Avatar
Sounds like a vss issue.
bittyboy3 is offline
post #3 of 11 (permalink) Old 09-04-2013, 12:39 PM
tilwedie00
Guest
Posts: n/a
No! this is a transmission problem. The exclamation light means the Trans oil is hotter then it should be. You, have a transmission problem. I would take it back to the shop and have them check it out. Good luck!
post #4 of 11 (permalink) Old 09-04-2013, 01:11 PM
Play Nice or Don't Play
jag1959's Avatar
Engine: 3.4L Yamaha V8
If light is coming on get codes pulled
Right neighborhood but wrong door, no VSS, '02 uses transmission speed sensors.
jag1959 is offline
post #5 of 11 (permalink) Old 09-04-2013, 01:50 PM
bittyboy3's Avatar
So use to working on the olders cars i guess lol. Hopefully, that transmission has a warranty.
post #6 of 11 (permalink) Old 09-04-2013, 01:55 PM
jag1959's Avatar
^+1
The VSS is like the IAC, it is so often a culprit we do it as a reflex
jag1959 is offline
post #7 of 11 (permalink) Old 09-04-2013, 02:38 PM
A quick basic question, did you check the fluid level? Mine had trouble going into gear early in the morning, but once I topped up the fluids, it was fine. Sounds like you might have other issues also.
2001 Taurus SEL
24V DOHC
henrysel is offline
post #8 of 11 (permalink) Old 09-04-2013, 08:12 PM Thread Starter
thanks
I have checked the fluid and it is fine. Of course the transmission is out of warranty. I guess the next step is to have the codes pulled. Wasn't sure there would be codes since no warning lights are on. Thanks for all the help.
post #9 of 11 (permalink) Old 09-04-2013, 08:56 PM
The CEL flashes for serious problems. (Danger, Will Robinson)
Codes will be stored. There called pending codes.
post #10 of 11 (permalink) Old 09-04-2013, 09:12 PM
jag1959's Avatar
If that light flashed codes are stored
jag1959 is offline
Weird transmission noise ??....video of sound Jmeinen12 Maintenance and Repair 13 09-05-2013 09:32 PM
The tool for taking off oxygen sensors? fct Maintenance and Repair 11 08-02-2013 11:59 PM
Transmission fluid leaking from filler/dipstick tube JayKay Engine and Drivetrain 5 07-19-2013 09:16 PM
1992 Taurus Wagon transmission mystery mroberts11 Maintenance and Repair 3 06-15-2013 11:28 AM
Gen 3/4 AX4S (AXOD-E) Transmission Guide Ultimatum Maintenance and Repair 33 04-29-2013 01:12 PM
