injector problems need help - Page 2 - Taurus Car Club of America : Ford Taurus Forum
Old 01-27-2013, 02:20 PM   #11 (permalink)
You're getting 80 PSI at the fuel rail? That's way too high. You probably have some kind of blockage in the return line or a failed pressure regulator.
Old 01-29-2013, 11:36 AM   #12 (permalink)
mr.b's Avatar
Member Number: 52446
Drives: 92 taurus sho mtx
mr.b is an unknown quantity at this point
thanks im gonna take the fuel rail and injectors off my old engine and give that a try thanks for responding
mr.b is offline   Reply With Quote
Old 01-29-2013, 10:58 PM   #13 (permalink)
jw89sho's Avatar
Member Number: 16867
Drives: 89 SHO 3.0 DOHC (Y)
jw89sho has a little shameless behaviour in the past
regulator is bad
Josh
Check this out...
jw89sho is offline   Reply With Quote
Old 01-30-2013, 12:30 AM   #14 (permalink)
A different fuel rail and injectors aren't going to change the pressure.
Old 01-30-2013, 12:48 AM   #15 (permalink)
Breeves002's Avatar
Member Number: 49890
I swear I saw another post where he said the regulator was good. So I would check for blockage in the return line.
Why wouldn't the injectors fire if the pressure is too high? The light lights up but no fuel comes out? Wouldn't an abundant amount of fuel come out? I guess it's possible the blockage is somewhere else?
2012 Kia Soul Base AT 1.6GDI
CLICK HERE
Old 01-30-2013, 02:09 AM   #16 (permalink)
If the pressure is too high, the magnetic force from the solenoid coil is insufficient to overcome the force on the plunger from the pressure. So the injector stays closed. Since fuel injectors are designed to deliver a precise amount of fuel, they are designed to operate with a specific pressure drop across the fuel injector. In the case of a Ford injector, the ideal pressure drop is 270 kPa.
Old 01-30-2013, 05:46 AM   #17 (permalink)
Member Number: 51650
Drives: 2004 SEL Vulcan
Rogerm60 is an unknown quantity at this point
A bad regulator usually results in 40 psi or leaks into the vacuum line.
Methinks the return line got damaged installing the engine.
Rogerm60 is offline   Reply With Quote
