Rpms are going crazy?!?!? - Taurus Car Club of America : Ford Taurus Forum
Old 01-15-2013, 01:34 PM   #1 (permalink)
Member Number: 46910
Drives: 2003 Taurus SES
dogcmp6 is an unknown quantity at this point
Default Rpms are going crazy?!?!?
The past few months my RPMS have been going crazy, spiking between 200 and 1000 (and you can hear the revving when this happens to) when I am coasting, braking, or driving at a low speed, since I have a hard time explaining things, here is a video of it 2003 taurus rpm issue - YouTube any ideas what could be causing this?
dogcmp6 is offline   Reply With Quote
Old 01-15-2013, 02:13 PM   #2 (permalink)
Are the engine RPMs actually changing with the tachometer? I can't really hear the engine in your video (microphone covered?).
If the engine sounds like it's running steady then I would suspect a crankshaft sensor.
Old 01-15-2013, 02:18 PM   #3 (permalink)
Oops, I meant to add that I can hear the engine reving with the tach
Old 01-15-2013, 03:25 PM   #4 (permalink)
Okay, then it's probably an IAC problem. Take it off (two bolts, save the gasket) and see if it looks real dirty.
Old 01-17-2013, 01:54 PM   #5 (permalink)
Pulled off my old IAC, there was no gasket, and the inside was dirty as all hell, bought a new one, popped it on with the gasket in 5 minutes, drove around for an hour, and no more problems!!!!! im so happy
Old 01-17-2013, 04:15 PM   #6 (permalink)
Congrats, glad it's fixed.
Old 01-17-2013, 11:24 PM   #7 (permalink)
Well, my rpms are no longer erratic while I am coasting, but now when I am at a stop, the rpms keep moving between 6 and 900
Old 01-17-2013, 11:32 PM   #8 (permalink)
You should check for vacuum leaks.
Old 01-18-2013, 12:42 AM   #9 (permalink)
There was not a gasket when I removed the old IAC, and I installed the new one with a diamond shaped gasket that was in the box, would this have anything to do with it?
Old 01-18-2013, 09:57 AM   #10 (permalink)
If you used the ∞ shaped gasket and your throttle body don't have a groove for it to fit in it's going to leak. If you have a flat surface, then you need a flat gasket like this:
